Hi, I have just found a puddle under my Xantia TDSX. I have looked under the car and it seems that the water is dripping from the centre of the cross-member that carries the steering gear. I hope that it is a hose thats gone and not the head gasket. There is no mayo in the oil filler cap and there isn't any sign of bubbling or bubbles of air coming into the expansion tank. I have to keep topping it up at a rate of one tank full every other day. It drips at a rate of about a tea cup full every hour (a rough guide).
Any ideas you guys???
Paul
Engine Water Leak
- x 1432
wrinklet1
oilyspanner
weety
wrinklet1
wrinklet1
Found out where the water is coming from.
It's coming from a T joint on a hose that connects to the engine near the turbo, then goes up to the heater matrix and over to the expansion tank Part no 96 144 896.
I also found a diesel pipe leaking from the pump back to the main supply pipes part no 1579 G3
Both pipes are big jobs but at least its not the head gasket!!!
Paul
Paul
adzbaby
wrinklet1
adzbaby
I went to a scrappie to source the water pipe, but I was a cit newbie at the time and I have a mark I Xantia and on this, the matrix hose has an extra pipe on it which goes to the header tank (absent on all other models) which I was unaware's about so I bought a mrkII pipe for £35 and it was useless, so I ended up paying that extra on top. I was quite sick for a while after that main dealer bill.
I was glad I got someone else to do the job, as it is a fiddly b**tard with the engine in situ, typically there's no room whatsoever.
Hey I could have sold you a matrix hose! ne'r mind.
macs
wrinklet1
jeremy
dnsey
- x 19
If the leak's in the actual hose (rather than the T joint), give it a good clean with meths or something similar, make sure it's dry, and wrap it well with decent quality self-amalgamating tape. Warm the joint with a hairdryer or similar, and preferably leave it overnight to fuse. It'll probably outlast the rest of the pipe!
wrinklet1
Sorted the water leak out. Replaced the 'T' joint that goes to the expansion tank from the hose that goes from the matrix to the lower engine connection. Replaced the 'T' with a piece of copper tube 22mm with a 15mm branch off it ie 22-22-15 brass fitting. Was quite an easy job, costing less than £10, a bit cheaper than the £119.81+ VAT that Citroen wanted. AND, I can replace most od the rubber hoses with copper if needed, now I know the sizes.
Paul
Paul
