Xantia Rear screen and heater fan not working help
zs&tas
x 16
Unread post by zs&tas »
Hi it's a MK1 xantia. Both heater fans and rear heated screen stopped working same time , I read some old posts with old links, I've got it down to a faulty ignition switch , if I wiggle the keys I can get the fan to work. I'm wondering on the easiest a-team method of fixation :mrgreen:
I love my lowish millage xantia but let's be honest its never guna worth any money so the a-team fix will do !
KennyW
x 165
Re: Xantia Rear screen and heater fan not working help
Unread post by KennyW »
You need to do the relay mod on the ignition as this was a problem with the Mk 1's.
I'll try and find the link.
Kenny
C3 1.4 petrol (SWMBO)
zs&tas
x 16
Oh thanks , that would be very much appreciated .
x 5672
Here's a link to the Wiki
zs&tas
x 16
Oh thank you so much, actually looks really easy, ive got the parts coming to do the job , many thanks !
ekjdm14
x 263
Unread post by ekjdm14 »
It is actually really simple and easy, can't be too many X1 running around without the relay mod already done. Strangely, we seem to have ended up with two of them showing no sign of it needing to be done yet... Because French electrics :D
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
x 5672
It may be sensitive to the weight of keys dangling from it.
You would think some folks were jailers with all the keys they cart around.
