Suspension pump spindle rotation.
seanrx
x 6
Unread post by seanrx »
Hi All.
I have removed and cleaned motor of my bhi unit and now I have a question about the 8-) pump spindle/ shaft only.
To anyone who checked their pump, how freely did the spindle rotate?
Was it free enough to rotate with one finger?
Or like mine, did you have to grip spindle end to turn and it felt notchy with some resistance?
ekjdm14
x 252
Re: Suspension pump spindle rotation.
Unread post by ekjdm14 »
No direct experience of this, but based on other pump mechanisms I've played with I can see the movement being "notchy" if it's still in-circuit and effectively trying to pump fluid as you turn it.
Hopefully someone has direct experience of this on the C5 though?
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
x 2942
I think there is bound to be some resistance as the valves open and close so notchy might be an expected condition.
seanrx
x 6
I seen a bhi drawing from Marc and it states 5 pistons surrounding the spindle, so with your replies it seems my piston is OK.
Have to be sure, as the motor I cleaned wasn't as dirty as expected, just a light coating of dust.
x 2942
Does the motor work after your clean?
seanrx
x 6
Not tested yet. Which I have a question for.
Going to follow a guide that I seen posted on here.
A 2nd wire is needed for the command switch, so that's 2 wires that must connect to battery positive?
Any grade wire will do instead of buying crocodile leads?
What I know about car electrics is four pages from online today. Oh Lordy.
