Xantia S2 Clutch Cable connection.
x 3280
Re: Xantia S2 Clutch Cable connection.
If you need to get new spheres you can do a lot worse than contacting AEP Direct. I have used them in the past, and they are thorough and fairly priced. I ordered a full set of spheres (6 in total), and they arrived within a few days. As the cost was over £50 the P&P was free. If you DO use them make sure to include your vehicle registration when you place the order, so they can make sure you have ordered the correct spheres (otherwise they will contact you, which will delay the dispatch by a day or so).
http://www.aepdirect.com/
