Synergie non-starter
Tonyb395
Hello, apologies if this has been asked elsewhere but a quick forum search didn't answer my question.
1996 2.0l petrol Synergie running beautifully until there was a loud crack/bang from the under the car and fuel delivery ceased. Engine turns over and fires if fuel is introduced via the air box. There is no fuel coming through the feed pipe to the fuel rail. With the ignition on I cannot hear anything clicking or buzzing so therefore am I right in thinking fuel pump failure? Ho would that explain the loud bang? Can I get to the pump via the interior or do I have to drop the tank?
Many thanks
Tony
Many thanks
Tony
- x 1443
Re: Synergie non-starter
Can you tell us exactly which engine is fitted to your car, or post your VIN so that we can look it up, in order to give meaningful advice.
Tonyb395
Sorry, yes; Engine no HJR23004244. VIN VFU6UB0012139505.
Thanks.
Thanks.
- x 6955
The VIN is missing a 7, but I've corrected that and it shows as a:
EVASION FAMILY SALOON 2.0 i Manual gearbox 5
INJECTION XU10J2 (XU/XUD)
MAGNETI MARELLI Injection system
Fuel Tank Diagram: Fuel Pump is 4
Tonyb395
Yes that's correct. Thank-you very much. Is the pump accessible via the floor or is it a tank out job?
- x 6955
I've just switched PC off as I'm looking after friends horses, as soon as I'm back I'll have a squiz at the procedure for you.
- x 1056
Its been years since ive been near a Synergie but im pretty sure its a tank drop down job to change the pump. Just like Xsara Picassos though you don't need to fully remove the tank just drop it at one side.
Must say ive never heard a fuel pump go with a bang
I would check if there is a power supply & earth at the pump when its turning over before buying a pump. Sometimes thumping the underside of the tank while someone is trying to start the engine can (temporarily) make the fuel pump start working again.
- x 6955
Just had a check and there aren't any procedures listed unfortunately.
Tonyb395
Thanks for looking anyway Marc. I didn't want to spend time taking the seats and floor out only to find I can't get to the unit anyway.
Wheeler- thanks for that. I was hoping to be able to test the pump without crawling around under the car but it looks like that's what's going to have to happen.
Regards to you both, thanks.
ken newbold
- x 4
You can access the fuel pump/sender unit by just lowering the offside of the tank, it will lower just enough to get it out, no need to undo the fuel filler pipe.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
Tonyb395
Thank-you Ken.
Had another look today and I don't know what has happened but the pump is working and there's fuel in the rail but still won't start.
ken newbold
- x 4
Crank shaft sensor?
- x 1443
If it went with a bang, I would be checking the valve timing.
Tonyb395
Ok, latest installment on the non-starting Synergie.
Not even the scrapman seems interested so I'm going to have to try and fix it somehow preferably without spending £500 it!
We have fuel in the lines and in the rail and there's a quiet buzz when ignition is turned on but...
The plugs are not sparking yet they're dry. So this obviously means there's no fuel being sprayed into the cylinder and no power getting to the spark plugs.
What does that leave me?
The ECU?
Mine is a Maget Marell OD IAW 8P_22 if that means anything to you.
Is there anything else that I could try?
The ECU?
- x 1056
If you have no spark & no injector switching this would suggest to me a crank sensor fault as it sounds like the ECU is powered up ok as the fuel pump is priming. Can you confirm if there is a live feed at the injectors when the engine is cranking.
