Broken pipe
matty1626
Broken pipe
Unread post by matty1626 »
Anyone know what this pipe is that has snapped off and roughly how much a replacement is my car is an 2003 Citroen xsara picasso 1.8 petrol
x 1995
Re: Broken pipe
Unread post by Stickyfinger »
Looks like a crank breaker pipe to me....I would just put a joiner pipe into it
x 3296
Re: Broken pipe
I recall that Michel had a similar pipe fail on his 307. When he tried to remove it (to repair it) it snapped a couple of more times!
x 1995
Re: Broken pipe
and £74 from Citroen !
x 3296
Re: Broken pipe
Bl00dy Hellfire! Michel only paid around £40 for his, new from Peugeot.
x 1746
Re: Broken pipe
Check for brittleness, then do a joiner. Worth a try.
x 3296
Re: Broken pipe
This was the problem Michel had, and the pipes look like they are made of similar materials;
viewtopic.php?f=4&t=58158
x 1746
Re: Broken pipe
Some black electrical flexi-conduit could turn out to be tougher, so long as it's not the stuff PSA use!
elma
x 284
Re: Broken pipe
Unread post by elma »
I got away with a repair on my Xantia with the same issue. At 21 years old and with the V6 heat I reckon if I got away with it you have a decent chance. I filled the external grooves with silicon and sheathed it with suitably sized fuel hose.
matty1626
Re: Broken pipe
Before i repair the pipe would i have to give it a good clean cause it was covered in oil
elma
x 284
Re: Broken pipe
Yes if you use an adhesive or sealer like I did.
I sprayed mine a few times with contact cleaner.
Probably not the ideal solvent but I didn't want to brush or touch the pipe for fear of it disintegrating.
x 1746
Re: Broken pipe
If the pipe is that delicate, the affected section should be replaced,
The only way to find out is to handle/flex it.
You may be able to splice in just a new section of that lengthy pipe.
x 1938
Re: Broken pipe
white exec wrote: 28 Aug 2017, 20:32The only way to find out is to handle/flex it.
Uh-oh, that way madness lies.
x 1746
Re: Broken pipe
Quite probably.
dnsey
x 19
Re: Broken pipe
Unread post by dnsey »
white exec wrote: 27 Aug 2017, 16:46 Some black electrical flexi-conduit could turn out to be tougher, so long as it's not the stuff PSA use!
That's what I used, attached / reinforced with heatshrink.
