Recomend source for Sphere tester Valve
- x 1997
As asked....can you recommend a source for a sphere tester valve ?
hattershaun
- x 4
Re: Recomend source for Sphere tester Valve
I'm not 100% sure what you mean, but worth looking at
www.tecnosir.com
http://www.tecnosir.com/ammortizzatori_ ... matici.php
David Hallworth has some valves for regassing green balls, can't remember if they are technosir.
If you need to pressure check spheres I have the proper Citroen device for doing this, on loan to a certain Citroen specialist in Welwyn Garden City.
www.tecnosir.com
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
SM 3.0 - 1972
DS 23 Pallas - 1975
- x 1997
I was going to build my own...............
- x 1746
Another vote for Tecnosir. They also sell the mating hose, as a spare part for their C720 regassing/pressure check tool.
- x 8422
If you're building your own Alasdair, just build a clone of mine... The only special bit is an adaptor to mate the gauge to 4.5mm pipe.. I turned one up on the lathe and brazed it together.
As I did for my in-line pressure gauge...
I can do the same for you...
- x 1997
I was going to build my own...............that was my plan Jim, can you bring yours down next visit so I can have a better look ?..........James can weld some pipe for me.
- x 8422
You are
I was only going to offer to make you the gauge adaptor
I will bring mine down next visit, no worries at all
- x 1997
I will build it Jim......we have still a few spheres to test (the C5 ones) and I have a stock of spheres now as well so would like to test those as well.
I can photograph yours (as it will be down here) so I can copy it................
- x 8422
Stickyfinger wrote: 25 Aug 2017, 13:28 I can photograph yours (as it will be down here) so I can copy it................![]()
Of course and naturally but remember mine is built with a sinker pump and an FDV regulator so yours, if you use a 6+2 pump and normal regulator, will differ in minor details which I'll explain when I see you...
- x 1997
Bump
Does anybody know a source for these valves ?
- x 1746
Still unsure exactly what you're after, Alasdair.
If it's the valve that screws into a sphere top (to replace the OE plug) and which allows regassing, then get them from Tecnosir. Quick enough delivery from Italy. Also pretty much the default valve to use for this these days.
Unless you need something else...
- x 1997
Nope, it is the dialled gauge that measures the pressure in the sphere......sorry I assumed
- x 1746
Pressure gauges on Amazon, including some up to 3000psi / 200bar.
- x 1997
Which type is suitable for LHM ...all of them ?
This OK ?
http://www.ebay.ie/itm/63mm-HYDRAULIC-G ... 2459828785
This OK ?
- x 1746
That will be fine. For sphere testing, get the 100bar/1500psi version, Alasdair.
