Picasso xsara radiator and air condition fan problem
ziggyzyg
Unread post by ziggyzyg »
Hi can anyone help me with this fault on my citroen picasso xsara 2008. I had the radiator fan running good but lately was doing a lot of noise and I realised the fan jammed. So I ordered a second hand one and tested it working properly but now still it is nor working when I switch the aircondition. Can anyone point what else I can look for to get the fan working please. I also changed the resistor. =D> :?:
x 5690
Re: Picasso xsara radiator and air condition fan problem
Have you checked the fuses?
If the fan was stalled it may have blown the fuse.
Welcome to the FCF :welc:
x 1955
I had to replace the fuse on both the Xsara and the Mk1 C5 when the fans seized on those. It was one of the big maxi-fuses. Can't be sure of the value but quite high - 45A maybe?
ziggyzyg
That is what I am after where the big fuse is? I am sure it's a fuse cause all is in working order now. On the manual that came with it it doesn't seem to show where the big fuse is. Any help in tracing where the fuses are please
x 1507
Post up the last 8 digits of the VIN and I'll see if I can find anything.
x 1955
On both of our old cars the fuses were on the same underbonnet fusebox as the normal fuses. IIRC on at least one of the cars the maxi-fuses were partially hidden and I had to release the fuse box (top layer?) in order to see these maxi-fuses. Maybe yours is the same?
ziggyzyg
Paul-R wrote: 16 Aug 2017, 13:14 On both of our old cars the fuses were on the same underbonnet fusebox as the normal fuses. IIRC on at least one of the cars the maxi-fuses were partially hidden and I had to release the fuse box (top layer?) in order to see these maxi-fuses. Maybe yours is the same?
ziggyzyg
RichardW wrote: 16 Aug 2017, 12:42 Post up the last 8 digits of the VIN and I'll see if I can find anything.
x 5690
Paul-R wrote: 16 Aug 2017, 09:34 I had to replace the fuse on both the Xsara and the Mk1 C5 when the fans seized on those. It was one of the big maxi-fuses. Can't be sure of the value but quite high - 45A maybe?
On my C5 it is 80A - which came as a shock as I had bought a 40A in case it had blown, fortunately it was OK.
ziggyzyg
ziggyzyg wrote: 16 Aug 2017, 15:40
You where right just found them as you said under the main fuse box there are 6 of them Maxi fuses and the 50 amp is blown. Will replace it 2morrow when I buy the part. Thank you all so much for your feedback.
x 1955
Excellent. Let's hope that that's all that's needed. On the C5 it was but on the Xsara I found that one of the speed reducing resistors was burnt out and one of the spades (blades) on one of the relays had corroded off.
ziggyzyg
Thank you all problem solved all working well now after replacing the fan and the 50 amp fuse.
Once again thank you
Tony.
x 1746
It was probably the fan jammimg that took out the 50A fuse.
If there are two fans, they will likely have one fuse each.
Glad it's fixed.
