Grrrr Electrics
doctle
- x 223
Grrrr Electrics
The lights on my clock display seemed to be getting duller so I took it out and changed all the bulbs now none of them works! Is there a fix or would using these do the job? http://www.ebay.co.uk/itm/2x-T5-Wired-L ... SwEetV9YO7. I also have power to my fog lights at the plug on the back of the light but no power to the bulbs on either side, how can this be possible?
Oh buggle
doctle
- x 223
Re: Grrrr Electrics
The electronics on this seem to be working so a 12v supply to the bulbs should work I'm thinking. New unit is dear used seems hard to find and are expensive. I'm thinking LED bulbs, is there a dedicated 12v wire for these at the plug or would I have to wire it to the fuse box or into the lights? Thanks
Oh buggle
- x 3296
Re: Grrrr Electrics
I would check the light bulbs that you fitted first. Some years back I bought a load off e-bay, and several did not work (a few of them were because the two wires were touching, so they were easy to fix, but some were open circuit), which necessitated me pulling the instrument panel out again (GRR!). Now I test bulbs with a multi-meter first before I fit them.
- x 5673
Re: Grrrr Electrics
I check mine with a 12V power supply to see they actually produce photons.
Been caught out in the past too
doctle
- x 223
Re: Grrrr Electrics
I tried the old bulbs as at least 2 were working before I started. I can't see any blown fuse either
Oh buggle
doctle
- x 223
Re: Grrrr Electrics
I checked the bulbs they all work, I took the white unit out of the cover checked the tangs on the bulbs etc and of course I lost one of the little rubber ends for the adjusting buttons
Oh buggle
- x 1240
Re: Grrrr Electrics
Have you checked the fog lights feed with bulbs connected, could be that you have a bad earth.
doctle
- x 223
Re: Grrrr Electrics
Peter.N. wrote: 12 Aug 2017, 23:12 Have you checked the fog lights feed with bulbs connected, could be that you have a bad earth.
Would there be separate earth for the fogs? I connected a voltmeter to the wire going to the bulbs but nothing there, low and high beams seems to work ok
Oh buggle
- x 1240
Re: Grrrr Electrics
Possibly not, modern cars are a mystery. I thought you said that there was voltage present at the lamps but they didn't work, if you have a high resistance connection it could read 12v until you connect the bulb and then drop to nothing.
doctle
- x 223
Re: Grrrr Electrics
Peter.N. wrote: 13 Aug 2017, 08:04 Possibly not, modern cars are a mystery. I thought you said that there was voltage present at the lamps but they didn't work, if you have a high resistance connection it could read 12v until you connect the bulb and then drop to nothing.
Hi Peter I'm up at at it again! There is power coming to the plugs that connect to the light cluster. Nothing coming to the fog light wires. I cleaned everything with Halfords finest electrical contact cleaner but no joy. If I take the clusters out I'll likely lose the settings and have to get the lights realigned!
Paul
Oh buggle
- x 1240
Re: Grrrr Electrics
You mean you have a live fog light supply at the connector but the lights don't work?
doctle
- x 223
Re: Grrrr Electrics
Peter.N. wrote: 13 Aug 2017, 16:03 You mean you have a live fog light supply at the connector but the lights don't work?
Yes new bulbs too just in case
Oh buggle
- x 3296
Re: Grrrr Electrics
That would suggest a poor earth from fog lights to chassis.
doctle
- x 223
Re: Grrrr Electrics
Hell Razor5543 wrote: 13 Aug 2017, 18:46 That would suggest a poor earth from fog lights to chassis.
there's only a single wire comes to the bulbs and it doesn't have any power
Oh buggle
- x 3296
Re: Grrrr Electrics
On an H1 (for example) there is only one obvious connector (and there is only one wire). However, the body of the bulb (where it clips into the mount) is the earth connection to the chassis. However, as you saw there is no power to the connector it suggests the problem lies UP the wire, and not necessarily with the earth, as I suggested (however, testing the earth could help to rule it out).
H1 bulb;
https://images-na.ssl-images-amazon.com ... X-2ApL.jpg
H1 bulb;
