The fan for the intior has started to make a dull rumble sound and was wondering if these are easy to get at. I guess the bearings are on the way out on the motor.
2011 c5 x7 intior fan
renagade
- x 10
Hi Guy's
There are so many roads to travel but so little time, (Paul Cofield )
renagade
- x 10
Re: 2011 c5 x7 intior fan
Come on Guy's one of you will know where the internal heater fan is mine has started to "chirp" on a medium to fast speed (like going into reverse when the heater fan speeds up )
- x 1996
- x 1488
I'll find the procedure later, but AFAIK it's at the back of the dashboard and can be access via the aperture made when the glovebox is removed!
- x 1488
This pic is from the front, ie the blower is on the LH side of the car:
This is from the procedure; it shows a LHD car, but suggests it is accessible from the footwell, although may be easier through the glove box on a RHD.
