Merged Lexia & Diagbox threads
x 6957
Re: Merged Lexia & Diagbox threads
Put anything in the top and scary01 on the bottom - see if that does it.
x 2941
Thanks I'll give that a try but it will have to wait until tomorrow now, other matters need to be dealt with.
discv
x 24
Unread post by discv »
Hi, new to your forum- but I need help!
I need to reinstall a newer version of Diagbox ( till the old laptop crashed I had 6.xx). My problem is trying to find out my interface version to establish which Diagbox version I can run.
The old installation DVD appears to list a PSA Version checker- but it just will not play!
Has anyone got a copy of the checker- or a link to it. Thanks in advance.
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
MikeT
x 232
Unread post by MikeT »
discv wrote: 12 Jul 2017, 17:52 Has anyone got a copy of the checker- or a link to it. Thanks in advance.
https://anonfile.com/32h6V3b2ba/PSA-Int ... hecker.zip
richieski
Unread post by richieski »
Anyone know why I see parameters on diagbox for my electrovalve as invalid value?
x 6957
You'll need to be a bit more specific than that. It depends on the parameters or test you are running. This could be perfectly normal if you are testing a system where the car is not able to return any data because it is stationary for example, like the ABS or ESP systems that rely on data when the vehicle is moving.
richieski
Major issue with car. No one can diagnose it
. https://www.berlingoforum.com/thread-15 ... #pid102120
I was stationary during the test. What I need is someone that can interpret the data.
Basically I have hesitation, egr codes p1459 and p0490 have had new egr fitted and reprogrammed by Citroën.
discv
x 24
Many thanks Mike T.
Now what is this telling me? Is that 'B' a problem device?
x 6957
Yes, that serial no. is blacklisted. You should be able to use it with Diagbox version 5.29 and Lexia and PP2000 though, but you may also need to downgrade your firmware version to 4.2.4 (APPLI 4.2.4DB.COM)
discv
x 24
I was using this interface with Diagbox 7.02 till my old laptop went bang recently. I had to go through Diagbox to talk to my C4 Pic.- but Lexia would do virtually nothing by itself.
x 6957
It is entirely dependent upon the model, year and electronic architecture of each vehicle, including the ECUs as to how much (or little) success you will have. You may find some dialogue with certain components and nothing with others.
discv
x 24
I hope I am not breaking any rules here- but could you gurus take a view on this item. To my untrained eye it seems to tick all the boxes.
http://www.ebay.co.uk/itm/2017-Rev-C-Le ... 3027936162
x 6957
I personally would not touch it - they can't even spell Citroen correctly, and in one sentence they say 'works good with C5 and 307' and in another sentence say that is doesn't!
I can only recommend easydiagnostics as we know theses are the full chip kits and there is UK support available.
There is a 15% discount too for FCF members here:
viewtopic.php?f=15&t=57989
They may not the cheapest, but at least you know you will be getting the latest interface with all the correct hardware, with UK support.
http://www.easydiagnostics.co.uk/shop/4 ... 7/11178597
discv
x 24
I've bought from easydiagnostics before- and agree they provide a good service. I just got a bit miffed when I could no longer access the members area because they changed their mind and made membership time limited- unless you paid more money.
And I've just noticed the feedback for the seller I linked- not good!!!!
x 6957
Regarding Easy.. you should have all the software supplied at purchase to be honest - just make a backup. There really wasn't much else there that isn't available elsewhere to be honest.
