2013 c4 picasso 1.6 hdi
Bigjohn12
Hi I'm new here I have a c4 picasso 1.6hdi I have various abs esp lights on when I run scanner on it it says 4% abdditive in tank I have put 1 litre in and still says 4% will not let me reset it also says no comms with abs unit anyone able to help thanks
- x 3296
Re: 2013 c4 picasso 1.6 hdi
First, let me welcome you to the Forum.
Now, what type of scanner did you use? If it was a generic ODB scanner it is unlikely to work, as the PSA group (being a law unto themselves, as they are French) tend to use their own protocols. You will need to use a Lexia clone (which talks PSA) to get the car to communicate clearly. There are forum members who have such equipment and are willing to help. If you take a look on the following link you can see who is closest to you;
viewtopic.php?f=19&t=56452
Unfortunately there does not appear to be anybody with a Lexia living on the Isle of Man.
Bigjohn12
Thanks for your help I think I will have to buy one they easy to use ?
- x 3296
They are easy to use WHEN you know how to use them. The Lexia is far more than a code reader. For example, when I added Cruise Control to my C5 I went into the menu relating to the Driver Switch Module, changed the option for Cruise Control from "Absent" to "Present", saved the setting, and tested the switches worked. If you want, you can see how the engine is running (in graph or numeric forms). It should be possible (assuming no issues) for you to let the ECUs know you have topped up the additive (although I do not know how to do this, as my C5 does not use the stuff).
If you were to contact Easy Diagnostics and give them the following code they will give you a 15% discount;
FCFMEMBER15
viewtopic.php?f=15&t=56324
You do need to be careful when using a Lexia. It is possible, if you do not take care, to brick an ECU. When I use mine I go with the attitude that, if I do not know what the ECU does, leave it well alone!
While a Lexia is nowhere as cheap as a generic code reader, dealerships will normally charge around £50 for a Lexia session. After a couple of sessions a Lexia will pay for itself (and if you help friends with Citroens or Peugeots you will help them save money as well). You will need a computer to run it on. I am using a Toshiba NB250 netbook, running Windows 7 Starter ( which is a 32bit version). If you want to run a 64bit O/S you WILL need to run a 32bit Virtual Machine, as the Lexia software is so old it CANNOT run in a 64bit environment.
FCFMEMBER15
Bigjohn12
Hi again I have some fault codes of scanner does anyone know how I can post the picture up here or can I email it to anyone that might be able to help
OnlinePaul-R
- x 1938
Assistance on how to upload photos here viewtopic.php?f=9&t=56795
Bigjohn12
Faults are
Additive adding the quantity of additive into fap has exceeded the maximum threshold the gap must be changed=permanent fault
Multiplexed additive adding pump
Pump fault
Permanent fault
Cam network fault or pump fault
Permanent fault
Fan unit bi-speed incoherence between the setting
(No command)and the cooling fan status
Intermittent fault
I not have two c4's both doing the same thing both just over 100,000 miles
Pump fault
Permanent fault
Permanent fault
Intermittent fault
MikeT
- x 232
IMO. Apart from the fan "fault", the othe faults appear a little contrary. The first one is stating that the maximum amount of additive (which can end up clogging the DPF) has been added during the lifespan of the currently fitted DPF. This implies the additive pump has been working as expected, hence the contradiction of the other faults, though it also possible it packed up after reaching this threshold?
A Diagbox/Lexia diagnostic session can "reset the counter" which should clear the first fault. Whether the DPF is actually clogged is another matter (the threshold counter is a "best guess") and again, a Diagbox/Lexia session can help determine the state of blockage in the DPF through the exhaust pressure differential sensors.
ETA
Assuming the (cooling or heater?) fan unit is faulty, this also needs investigating for obvious reasons and because it may be inhibiting DPF regeneration.
ETA
Bigjohn12
Hi just an update on this and maybe some more info I sent the abs pump of for testing as all the latest faults pinpointed no comma with abs unit the results come back unit ok what else could cause this I know I have got power going to abs unit as I've tested that any insight would be much appreciated
