Part number look up, please.
- x 2941
I need a heater blower resistor for my C5, ordered one from an Ebay supplier, got the wrong one despite it being right according to the listing for my reg number.
Supplier is asking for the oem part number.
Vin is: VF7**************[VIN obfuscated, can be read by forum staff] DCRHZB 76455349 2004 2.0L HDI VTR hatchback. RPO 09733 CJ
- x 1487
Re: Part number look up, please.
Slightly complex...
6441 T6
01
HEATER MOTOR CONTROL MODULE
SEE A
A)FOR VEHICLES EARLIER THAN 02/04/04 CUT HARNESS
AND USE ADAPTER + BOLT
Yous is 3rd July 2003, so this applies. You should get the resistor plus a length of cable - you need to cut the old one off and solder the new one on.
6441 T6
01
SEE A
- x 2941
Thank Richard, I did wonder if that would be the case.
Onlinemyglaren
- x 5674
If it is the same as this one:
I have had three, one from the dealer, two from eBay, (China).
Last one still running fine, £20, no adaptions required, other than the plug I chewed up replacing it - had been bodged before I got the car and the wires caught fire melting the plug.
- x 2941
That's the same as the one from Ebay, the original one has a green block of ceramic where the ali fins are on that and the connections are a different shape.
Similar to this Ford one.
https://www.amazon.co.uk/Micro-Trader-1 ... MYMAART3AG
Onlinemyglaren
- x 5674
Odd that there are no heatsink fins - they get very hot.
I burned myself retrieving mine when it fell out of the ducting - it wasn't fitted properly, screws hadn't been replaced.
Dropped under the clutch pedal which made for an interesting moment or two.
Onlineekjdm14
- x 263
I take it the breaker doesn't have a correct item, being an 06?
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
- x 2941
I'd guess not, seems it changed early 2004.
Struggling a bit, the supplier seems unable to understand and has now offered me the same part again from Ebay France.
- x 2941
Ebay supplier now says "Return it." and supplies a China address.
I've been on to Ebay and they've refunded, say he misrepresented his location as UK.
- x 2941
Re: Part number look up, please. still struggling
I'm still stuck on this, nobody seems to have the right part or a later part with mod. There's a used one on Ebay from Lithuania that looks as though it's been buried in a pit for a long time.
This is the offending part.
Onlinemyglaren
- x 5674
There's one in Poland.
£21.49.
£21.49.
- x 2941
Almost Steve but the connections are different.
Onlinemyglaren
- x 5674
Oh bugger
- x 2941
- x 1942
I've mentioned these people before although I've not used their services. They sell repaired units, or repair your unit, for various cars.
http://www.heaterblowerresistor.co.uk/c ... istor.html
