Economy mode
waynedance
x 8
Economy mode
Unread post by waynedance »
Is there away to switch off this feature?
Sometimes sit in the car using the radio to watch videos over Bluetooth and the economy mode kicks in after so long.
If no way to switch it off would it hurt to add another wire direct to a permanent live and have it on 2 way switch. Switch between the normal ignition and permanent live, any problems foreseen here.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
milleplod
x 15
Re: Economy mode
Unread post by milleplod »
Its bloody annoying, isn't it! I think the question's being asked before re disabling it, and the answer is a resounding 'no' unfortunately. My wife has a Doblo van, '57 plate.....after around 15 mins sitting with the radio on and the engine off, the radio switches off.....but you can switch it back on again. So, no chance of leaving it on all night! That seems a much simpler, and just as effective, way of preventing a flat battery. But I assume there's a good reason for Citroen's overly-complicated method of achieving the same thing! :-D
Pete
Nocto Diuque Venamur.
wurlycorner
x 271
Re: Economy mode
Unread post by wurlycorner »
Don't know if you can turn it off, but you can adjust the timeout before economy mode becomes active, using lexia.
BTW, it may be annoying, but also (given the problems that can occur on a c5 if the battery goes flat) a very good fail-safe measure!
Iain
CX DTR T2 Safari (silver)
waynedance
x 8
Re: Economy mode
I will get lexia on the car tomorrow at work and have a play.
Thanks.
x 1955
Re: Economy mode
It's so bloody annoying that I'm looking for a small form standalone radio that I can run off a direct connection to the battery. The type that would fit in best would have a separateable front panel and I can bung the guts somewhere else.
The trouble is that as well as VHF I want it to also have MW and LW reception. LW is important to me for my travels through France.
sutty86
Re: Economy mode
Unread post by sutty86 »
looked around my lexia protocol and cannot find where to change bet its something super simple
x 1506
Re: Economy mode
You can't change it on later cars - and how long it takes to trigger is related to how long the engine has run in the previous cycle. It seems to come in quicker if the battery is not so good.
milleplod
x 15
Re: Economy mode
RichardW wrote: 13 Jun 2017, 12:12 You can't change it on later cars - and how long it takes to trigger is related to how long the engine has run in the previous cycle. It seems to come in quicker if the battery is not so good.
I fitted a high-Ah, high CCA battery in December.....it made no difference to the time taken for 'economy mode' to kick in, which seems to be around 15 mins whether I've been driving for an hour or 5 minutes. :?
Pete
x 1955
Re: Economy mode
milleplod wrote: 13 Jun 2017, 14:33...it made no difference to the time taken for 'economy mode' to kick in, which seems to be around 15 mins whether I've been driving for an hour or 5 minutes.
Luxury! More like 5 minutes in my car.
wurlycorner
x 271
Re: Economy mode
Hard time based function on my 01. Set to 30mins atm (what it was when I bought it).
If you can't adjust it on later models (is 03really that much later?!) then it's just another very odd example of them removing functionality (e.g. remote window open) and adjustable parameters for no seemingly good reason!
Iain
waynedance
x 8
Re: Economy mode
Managed to change the setting today from 30 to 120 minutes with a Lexia.
Not tried it but I do not see why it has not worked.
Thanks for help.
Ps is it just me or is Tapatalk not working on this forum?
x 2008
Re: Economy mode
Unread post by Stickyfinger »
Tapatalk does not work now, that function has been withdrawn for security reasons
waynedance
x 8
Re: Economy mode
Is that a permanent thing with Tapatalk? So much easier to use and add photos.
What do you mean security reasons?
x 5689
Re: Economy mode
Explanation of withdrawal of Tapatalk here.
