x 2000
Re: I am an Activa owner...a V6 and I am an addict
Unread post by Stickyfinger »
Got sick and tired of false Empty warnings and levels from the fuel tank......so swapped the sender over for a cleaned one taken from the pump on the scrapper car.
You can see the build up of crud you can get
x 8423
And that's in a petrol car.. In a diesel it is far worse... Veg is even worser...
x 2000
It never rain but pours...out on the test drive to check the fuel tank sender was working and this happens. Stones + truck = guess :(
Replaced....bugger
x 8423
Bol**cks :evil:
Do you need one?
x 2000
Used one of my spares Jim ...ta
x 2000
Well there you go......The French SUCK....or is it blow ?
Had an interior blower fan problem, intermittent. So I grabbed the one from the scrapper which I knew worked well and fitted that, and it worked so I put it all back together, then had to go out....
On the trip to the hill climb last weekend I put the fan on.....it worked but no Air came out the vents....rats.
Well Jim was correct.....LHD cars have the fan blades in the other direction !
So I was Blowing and not Sucking.....
Gutted the fan, new brushes, swapped the controller and put it all back together....I now SUCK very well.
demag
x 102
Unread post by demag »
I knew you were a sucker Alastair. ;-)
Dave
x 2000
Jim told me I could be :)
x 8423
Ahh! That's excellent news Alasdair....Pleased all is good again :D
demag
x 102
Is that the dreaded dashboard out job?
Dave
x 2000
Nope, just the fan so access via the trim under the glovebox.
Well the repaired fuel sender seems to be playing up now....Today I have even replaced the loom and connecter to it and it is still all over the place....next will have to be the fuel gauge I think................
x 8423
Stickyfinger wrote: Well the repaired fuel sender seems to be playing up now....Today I have even replaced the loom and connecter to it and it is still all over the place....next will have to be the fuel gauge I think................
That's bloody aggravating Alasdair :twisted:
Hopefully just a dodgy connection on the instrument PCB... IIRC on an S1 the gauge is held in and gets its connections through studs with small nuts and they can work loose and cause intermittentcies...
x 2000
It just drops to zero every now and again.....aggravation for sure
x 2000
Well the spare engine (green goblin) is still offering up good parts....I have a squeak on start-up which (may-be) the crank shaft pulley
This one looks almost spot on.....no cracking or any other signs of problems with the rubber insert.
x 8423
Alasdair, I can tell you that pulley is quite new as I replaced it when Sid the Squid owned the Green Goblin...
Fingers crossed it fixes your squeak!
Don't throw the old pulley away as they are sure to go NFP soon; for the future our Lithuanian friend is able to refurbish them ;)
