Ok Marc now running Daemon lite and its veryfying.
Merged Lexia & Diagbox threads
demag
- x 102
Re: Merged Lexia & Diagbox threads
Dave
demag
- x 102
I am now on diagbox setup. So internet on?
Dave
- x 6947
1) Completely remove old installation from laptop with uninstall prog and CC Cleaner
2) Reboot and ensure anti virus disabled
3)Ensure Internet adapter is on.
4) If you want me to take a look install Teamviewer and I'll check everything remotely for you:
https://www.teamviewer.com/en/download/windows/
Just send the connection ID and Password to me via Private Message - it only takes 2 minutes
demag
- x 102
Hi Marc well I manually activated ok this time and it is now doing the full install of diagbox. If it goes belly up this time I'll let you know and I'll delete all files and log you in and you can watch. Going for tea now while its installing. Cheers.
Dave
- x 6947
No worries, just shout if you need a hand.
demag
- x 102
Installed ok now doing version update to 7.02
Dave
demag
- x 102
All looks good and got to run program however its as black as hell again outside so can't check it. I need the extension to run the laptop.
Dave
nono03260
GiveMeABreak wrote:No problem - if you don't have the cable there is one here that looks like the one you want:
http://www.ebay.com/itm/322315560101?rmvSB=true
Is this any good?
http://pinoutguide.com/CarElectronics/p ... nout.shtml
Here's another image of the pins:
https://i39.servimg.com/u/f39/14/77/57/30/van10.jpg
Sorry Marc,
I may have misunderstood, my English is not very good.
It's an official diag2000 pr37, ada16 obd interface that I'm looking for, at least its schema.
demag
- x 102
So near yet one million miles away!
Its now booting it down again so packed up having a nice cuppa and watching the cycling on TV.
Frustrating or what? I tried various ways of starting it up and sometimes the app would find the vin and other times it wouldn't. But I always ended the on the same screen.
Dave
- x 6947
Ok have a break Dave! I'm out doing the weekly shop, but if you want to me to have a look at it later today, I'd be happy to dial in and take a look / reinstall for you.
demag
- x 102
Ok Marc.
Dave
MikeT
- x 232
I had to make my own cable and recall the ordeal getting the pinouts right, so I sympathise with your plight.
I do still have the cable but it's stored in the back of an overfilled shed and I'm not certain I kept the paper sketches I made with the various proposed pinouts I used, sorry.
Deanxm
- x 87
I thought i should just tack my question on here.
I have had the Lexia for a while but i let the father in law borrow it for a while and due to a duff battery the laptop died and the Diagbox program became corrupted, he re-installed it but only diagbox appeared and he said he could not install any of the updates.
I used it for a bit and sorted the laptop memory battery out and today decided to reinstall the Program, i first had a pop-up saying Diagbox was already installed and i should un-install so i clicked OK and it started doing its thing, i then started the install, selected the language and it started doing it thing and then this pop-up window appears.
IMG_3352 by Deanxm, on Flickr
Turned off the fire wall and made sure the internet connection is ok, running windows 98 (i think) 32bit, nothing else on the laptop, no anti virus etc but has made no difference.
Anyone else had this issue?
D
IMG_3352 by Deanxm, on FlickrTurned off the fire wall and made sure the internet connection is ok, running windows 98 (i think) 32bit, nothing else on the laptop, no anti virus etc but has made no difference.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 6947
It would seem it was running XP Dean, but the uninstall routine does not completely remove all the previous installation and requires the Diagbox cleaner utility to remove all the registry entries and the application folders.
Trying to reinstall over a prior installation generally won't work.
Deanxm
- x 87
I tried running the uninstall or cleaner program but i get a sarcastic message pop up that says 'folder is empty so there is no point clicking here ; ) '
Not sure what that is about, it does that for both the uninstall Diagbox and clean tabs.
XM Prestige PRV6 92
