leccy talk
lexi
x 134
leccy talk
Unread post by lexi »
How do you make up a rated load to test a generator? This Honda EX650 needs a rated load of 350 watts to set the frequency and governor. Is it as simple as picking out a power tool of that wattage, or is that not accurate?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1438
Re: leccy talk
Unread post by xantia_v6 »
lexi wrote:How do you make up a rated load to test a generator? This Honda EX650 needs a rated load of 350 watts to set the frequency and governor. Is it as simple as picking out a power tool of that wattage, or is that not accurate?
You need a constant load, a power tool is usually a variable load.
Old-fashioned light bulbs are probably the best for your purpose.
lexi
x 134
Re: leccy talk
Sounds good mate. I will look stuff out.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1751
Re: leccy talk
Yes, a tungsten load would be the best. Avoid anything inductive (motor, transformer, fluorescent light...) because it will have a power factor that will make the load complex.
Bit of old-fashioned fairground lighting... :idea: :idea: :idea: :idea: :idea:
x 8309
Re: leccy talk
Old electric fire elements ;)
Proper standby generator dummy loads basically use giant versions of them with forced air cooling...
Chris, very good point about inductive loads with their complex impedances and power factor considerations...
lexi
x 134
Re: leccy talk
Dummy loads is what I was thinking of. That's what they use in invisible weight lifting competitions ! :lol:
Thanks guys. I pm'd cousin Simon as well, so I am well informed now,
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 3299
Re: leccy talk
In the early days of the PC the various power connectors had (if they were not connected to anything) to have a dummy load, otherwise the switched mode PSU would not switch, and could (on very rare occasions) fail.
