All change at demag towers.
demag
x 102
Unread post by demag »
I'm afraid Madame Syn has now departed and been replaced by an 04 C5 Exclusive estate 2.2 hdi auto which we collected from Derby today. The drive home was a very relaxed affair cruising at a leisurely 55-60mph. However there is one minor concern, the door mirrors no longer adjust or fold. When we test drove the car last week they were perfect. It had to have some work done for the mot and I'm wondering if the battery was disconnected. Could this be a possibility that a bsi reset might fix?
Dave
x 3298
Re: All change at demag towers.
I wonder if cleaning the driver door switches would help here? You can (using the Lexia) test the switches, and they are not difficult to remove and clean (took me less than half an hour, first time I did one). Nice looking C5, by the way.
demag
x 102
Thanks James, I assume they flick out with a small screwdriver? It's just odd they were perfect last week but totally dead today. Luckily I could still see through them as they were but half the view is taken up by the side of the car. Everything else seemed fine.
Dave
x 3298
The whole assembly is held in place by 6 flexible clips (three per side), so should lift out reasonably easily. There are two plugs (one with 3 wires, the other with 6) that are of the same design, that latch into place. Once you have unplugged them, you will see (on the underside) there are 9 clips holding the bottom cover in place (be careful, they look fragile). Once you have got the bottom cover off you can lift out the circuit board and membrane to clean with proper contact cleaner.
Saying all this, a BSI reset could well resolve the issue, if the battery was simply disconnected.
lexi
x 133
Unread post by lexi »
It's very nice Demag.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 2004
Unread post by Stickyfinger »
Good colour for it as well.....
daviemck2006
x 485
Unread post by daviemck2006 »
The mk1 c5 estate suits the silver and the 16" alloys that style. Nice motor.
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
demag
x 102
Silver? Silver! It's not silver it's gold! :rofl2:
Actually I'm quite pleased with it so far, hopefully the mirrors will be something silly and there's one or two minor blemishes on the body but generally it's good.
Dave
x 2004
Silver ?? reset that screen :)
A BSI reset solves all sorts on C5's
x 1240
Unread post by Peter.N. »
Its from Wales - that's the problem :wink:
x 2004
dare b Gold in dem dare hills
demag
x 102
We spend a few weeks a year in Llandudno and it used to live just down the road.
Sent from my Nexus 7 using Tapatalk
Dave
daviemck2006
x 485
Re: RE: Re: All change at demag towers.
Peter.N. wrote:Its from Wales - that's the problem :wink:
And I'm from Scotland lololol
Peugeot boxer 2016
In the family
x 8428
Looks sweet Dave... Hope your and her get on very well. No shortage of space that's for sure! MK1 C5 estates are like a tardis!
x 3298
If I have the tailgate open I find the echo lasts for seconds on my C5 estate!
