Do I have a traction control or ESP button????
Harlequin
x 23
Re: Do I have a traction control or ESP button????
Unread post by Harlequin »
mine is a mk1 - so assume the same ?
x 6947
I would assume so, if you have a button to deactivate it, there should be a light on or near the switch that comes on when you press it. When it re-enables, the light should go out indicating the system is active again. In either case it should revert to the active default once the ignition is switched off.
Here's a list of the functions and when / how they operate in case you're interested (click table to zoom):
C5 MK I ABS ASR ESP Teves MK60 Functions
