I am not intelligent about cars equipment, but where is the traction control button on my 2.0 HDI 110 VTR 2003 hatchback as I did not know it was on the list when I have bought the car and forget
Do I have a traction control or ESP button????
fv43576
- x 3
I could not find info on other forum:
to try the traction control on wet, Now I have remember after 3 months I have been looking for the button everywhere! and I could not find it!!!
citroenxm
- Fallen Hero
- x 70
Re: Do I have a traction control or ESP button????
You dont have traction control on c5s its ESP .. Electronic Stability Control. Its a brakeing control rather then a power delivery control...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
fv43576
- x 3
Right ESP where is the button?, what location I am expect to see? I only see 12volts plug with plastic cover near handbrake and other hole on right above gear knob
- x 3306
On my C5 that hole to the right of the gear lever is for a cigarette lighter. It sounds like the lighter itself is missing.
- x 2941
It's an item only fitted to some models, I doubt you have it on your car.
If you do have it it will have a deactivation button near the gear lever in the position directly opposite to the cigar lighter, activation is automatic when you switch on the ignition.
citroenxm
- Fallen Hero
- x 70
Ahhh 2003 VTR... they do not have it.. only exclusive in phase one has esp/esr...
its phase 2 facelift from 2005 onwards that have esp as standard... sorry I miss read originally..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
fv43576
- x 3
Right I see that I don't have ESP really shame should be standard on every car to prevention accident but thanks for your help
Fab.
Fab.
Xantidote
- x 5
ESP might be nice to have, but I hope you wouldn't be relying on it. Those of us who have been driving two or more decades never had it when we first started driving (and, to date, I've not yet regretted not having it)
Martin
1995 Xantia TDLX (deceased
lexi
- x 134
Yeah, the more things with three capital letters on a car, the more trouble in the long run!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
nagy592
Is it something like Cruise control? I mean I had no cruise control in my SX model, but I bought the switch then I enabled via Lexia and it works like charm. I also see ESP on the accessory list on Lexia. Is it came alive if I enable it?
Cheers
RP
Cheers
RP
- x 6956
No, don't change anything here, or you could interfere with the correct operation of the vehicle.
You simply don't have the necessary equipment on your car. Your model does have ABS, EBA (Emergency Brake Assist) and EBD (Emergency Brakeforce Distribution) which all help to stop the car quickly and safely.
nagy592
Thanks Mark at the moment I have other headaches as the suspension started to playing up, the question was only theoretical
- x 6956
Good luck with the other issues, I'm sure you will find the help you need here.
Harlequin
- x 24
I have seen my ESP come on when accelerating quickly from a wet junction and the inside wheel started to spin
- x 6956
Mark IIs with ESP have the button to temporarily disable the system (for extra wheel spin to help regain traction when icy or on deep mud at start off for example) bit it will automatically re-enable itself at about 30MPH / 50 KMH.
