Sump drain plug
glenndaleuk
Sump drain plug
Unread post by glenndaleuk »
xantia 1.9td vsx
Hi
Can anyone tell me the size of the allen key for the sump drain plug.And is it a std. size or is it a special ??
Many Thanks
Glenn
weety
Unread post by weety »
on mine you can use a socket a 19 if memory serves me right
Richard Gallagher
Unread post by Richard Gallagher »
What year is the car? Early ones up to about 95/96 had a 8mm square hole (round shape plug), whereas later ones had a 21mm nut hexagon outer shape with an allen key inside. (can't recall size).
rotodiesel
Unread post by rotodiesel »
The later sump plugs with the hexagonal inner recess are in fact 20.8mm across the flats of the outer hexagon. This seemingly idiot size is in fact the same as a standard spark plug, so use a plug spanner socket on these drain plugs.
Being French, this applies to the diesels too.
rotodiesel.
x 1485
The allen key is 8mm.
NiSk
Unread post by NiSk »
Topsy-Turvy Citroën - on my '93 XM TD12, the oil sump plug was an outer hex 21mm, while the "new" '98 XM 2.5 TD has an 8mm square recess! I guess they fitted what they had!
//NiSk
Kowalski
Unread post by Kowalski »
The sump plugs on my two can be removed with a 21mm hex, the later one has the square recess too.
