Flow divider XM / Xantia
noxati11
Unread post by noxati11 »
Hi, I've dismantled the flow divider for cleaning and adding shims under springs. Along with that, I wanted to add all new O rings, even in the "magic bolt." :roll: Unfortunately, I wrongly marked the bolt with nut and now I do not know how to properly configure it. Can anyone advise me ? :)
Here: http://www.club-xm.co.uk/forum/viewtopi ... 31a3435f63 is pretty well described function, but not, how adjust it. :D
Xantia 2.0 16V 112kW
Xantia V6 Activa
aerodynamica
x 215
Re: Flow divider XM / Xantia
Unread post by aerodynamica »
Hi there, that link you provide was written by my terrible self a few years ago and it covers investigations into the working of the FDV valve used in BX, XM and early Xantias with PAS.
I'm wondering if you are mistaking the FDV valve for the 'Pressure Regulator' (PRV) ? because the PRV has a bolt (12mm) to release the accumulator pressure but there is no 'bolt' in the FDV.
Graeme
Graeme M
noxati11
Definitely not :) here is pic of bolt that I have on mind:
Xantia V6 Activa
aerodynamica
x 215
Ah, I am with you now!
Not so much a bolt but I see what you mean. It is the screw used to adjust the power steering 'full lock' pressure to stop it spiking and causing the steering ram to over pressure.
I don't have the method to set it but I think the Citroen service manuals for this outline a method of connecting a pressure gauge to the PAS output from the FDV valve (the smallest of the pipes from the unit with the 9mm union nut) I think you turn the screw clockwise with the engine running and with the steering held at full lock until the pressure reaches something like 90-100bar. Then you lock the screw there.
Or maybe someone with a spare FDV could loosen the screw and count the number of turns to remove? I have a spare FDV I could look out in due course and measure the number of turns and report back. I think though, as a rule of thumb, setting the screw until it is level (flush) to the surface sets it in the general region to work properly. If anything, being a little too 'low' set will just make the PAS a bit heavier. If it's screwed in too far though it might cause it to over pressure at full steering lock.
So I think it'll work ok if you temporarily leave it screwed in flush to the surface because I think that is the minimum insertion as I've never seen one where this screw was left protruding.
Not certain if that really helps but it's a response!
Graeme M
aerodynamica
x 215
I just noticed you have a 1993 Xantia 16valve 'sinker' - that is a really rare model!
I was also wondering why you had to add shims to the springs as I ony found that necessary on my two XMs. All of my 3 Xantias with FDV just seemed to work! Di you find that the FDV was making a long 'hsssss' noise that will not stop? And also the suspension takes too long to raise?
Graeme M
noxati11
Thanks ! Yep it helps. That's what I'm asking :)
Xantia V6 Activa
noxati11
aerodynamica wrote:I just noticed you have a 1993 Xantia 16valve 'sinker' - that is a really rare model!
Yep it is... ACAV variant.
Xantia V6 Activa
aerodynamica
x 215
Pictures!!
Graeme M
aerodynamica
x 215
I was also wondering why you had to add shims to the springs as I only found that necessary on my two XMs. All of my 3 Xantias with FDV just seemed to work! Did you find that the FDV was making a long 'hsssss' noise that will not stop? And also the suspension takes too long to raise?
Graeme M
ekjdm14
x 261
Unread post by ekjdm14 »
aerodynamica wrote:Pictures!!
yes please!
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
noxati11
Both of it. Not too much, but "hisss" was significant during cold start and during ride on idle. Also, the engine was on GR, so if it was removed, what not do some "renovation" :)
I'll find some pictures what I have and I'll post it here :)
Xantia V6 Activa
aerodynamica
x 215
yes please!
:rofl2:
I meant: Pictures of your Xantia please!! haha I am an enthusiast of early Xantias!
All in good time though. Chat soon!
Graeme M
noxati11
Here are some pics of my RFY Xantia :)
Xantia V6 Activa
x 1450
Unread post by xantia_v6 »
For some reason the image links you are using are not compatible with this board, but I have edited one above so that it works: Go to you image hosting site and find the bbcode link for the image, but only paste into this forum the part between [img]xxxxxxx[/img] Then they work, I left the others for you to edit.
noxati11
xantia_v6 wrote:For some reason the image links you are using are not compatible with this board, but I have edited one above so that it works: Go to you image hosting site and find the bbcode link for the image, but only paste into this forum the part between [img]xxxxxxx[/img] Then they work, I left the others for you to edit.
Thanks, it's now corrected :)
Xantia V6 Activa
