Live feed from battery in C5 X7
This section is for General Enquiries or for Systems not Covered Above
x 6957
Re: Live feed from battery in C5 X7
Xantippa wrote:Here is one possible place in the right side footwell:
I guess that's the place where steering axle goes in the countries where they drive on the wrong side of the road. :roll:
And some say at finnish forum that there's also readymade hole for big cable in the drivers footwell.
Just don't try driving on the 'proper' side of the road in the UK :rofl2:
Yes, that looks like the 'proper' :-D place for the steering column and may well be a suitable location with some good grommet protection.
ajorge
Unread post by ajorge »
So that picture is taken on the passengers side, near the gearbox tunnel behind the carpet right? Or is it on the wheel side?
AJ
Enviado do meu iPhone usando o Tapatalk
Xantippa
x 29
Unread post by Xantippa »
Yes thats from passenger side and gearbox tunnel is there on the left side of the picture. I didn't take that picture, but seems very familiar.
But I'd look also to the driver side footwell carefully if there's that hole you don't even have to drill.
ajorge
On the drivers side it should be behind the foot rest?
Can you lead me to that finnish forum post?
Thanks a lot everybody :)
AJ
x 6957
That was "Xantippa" regarding the Finnish Forum, though I'm sure he'll be able to direct you to it. :)
ajorge
Sorry :)
I was reading in my phone and got confused...
AJ
Xantippa
x 29
ajorge
Thanks a lot. I'm going to refresh my finnish knowledges (aka google translate) :)
ajorge
Some news from the battlefront:
I've found two holes with rubber covers in the passenger footwell, and they look like places for running a loom (probably on the rhd cars).
Does anyone believe this could be used?
Best regards,
AJ
x 3306
Make sure to get a rubber grommet into one of those holes to protect the wiring as it passes through, otherwise you could have electrical issues later on.
ajorge
My only problem right now is that both holes look like they don't have another hole in the inside.
I try to put the cable but it seems as there is no connection to the other side...
Should it be like this and I need to open an hole on the other side? Where should this holes run to?
Best regards,
AJ
ajorge
Hello.
Just made hole in same place as photo from Finnish forum.
Xantippa:
In the Finnish forum they make any reference how to go from this hole to the engine compartment?
From the google translate I can't understand what's the next step ...
Best regards,
AJ
Xantippa
x 29
I think he just used drill with angle drive to drill that readymade hole all the way to the engine compartment. Other picture shows place where the hole is in the engine compartment. He made the hole for interior heater cable and that cable is armoured and visible in the center of the second picture.
ajorge
Thanks Xantippa.
Maybe my problem is the angle. I was trying to open the hole "straight ahead"
I'll look at it with an angle driver and with the car lifted.
Once again thanks for your kind help.
Best regards,
AJ
ajorge
Hello everybody.
With the car on a ramp and without the lower protection it was much easier to confirm the hole and pass the cable.
Thank you very much to you all for the kind help and smart advices how to deal with this job.
Best regards and an happy Easter from Portugal.
AJ
