Xantia rear suspension leak
froggy
- (Donor 2026)
- x 4
Hi, my S1 Xantia has a leak on the rear suspension cylinder . The rubber boot has perished .... now leaking from the cylinder ! Anyone know where I can get any spare parts ? is it citroen only ? many thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 2000
Re: Xantia rear suspension leak
Rare for the "cylinder" to leak....are you sure it is not just the leak off pipe has broken/detached ?
froggy
- (Donor 2026)
- x 4
yes its the cylinder........the pipes are ok
Terry
froggy
- (Donor 2026)
- x 4
I think the rubber boot has perished....... resulting in the cylinders' seal to leak !!
Terry
elma
- x 284
I think you're probably looking at a used unit or a repair from someone like pleides.
- x 2000
Part 3 ?.....the two pipes are return pipes....how much "flow/leak" of LHM are you getting ? Large puddle or small puddle ?
Forgive me if you know for sure.
froggy
- (Donor 2026)
- x 4
I am in the Gloucester area.
Terry
- x 2000
I am near Frome/Shepton.....I am breaking at Mk1 atm. Can you make it here ?
The car is up on Ramps and depressurised, wheels off the rear.
froggy
- (Donor 2026)
- x 4
Yes..... is saturday morning ok ? and how much would you like for it ? If your R P number is after 06779 . then the seals are available ! mine is before
What a lot of nonesense !
Terry
- x 2000
Sat morning is fine, please be early as you can, my Mothers birthday so I have to take her out for lunch.
R reg standard Non-HyActive.....should be OK.
£20
BA (four) (four) LL
£20
BA (four) (four) LL
froggy
- (Donor 2026)
- x 4
see you saturday morning.... can you send me directions... post code, cheers Terry.
Terry
- x 2000
I did....
BA (four) (four) LL
You will spot the Citroen's....about 200 yards up the hill (the end of 3 cottages)
See you Saturday
BA (four) (four) LL
See you Saturday
- x 1496
- x 2000
c.morewood
- x 55
Hi Terry, I can empathise with your struggles with the pin. You'll probably have to destroy it to get it out. This thread might help.
https://www.frenchcarforum.co.uk/forum/ ... =3&t=43884
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
