Oil light
born2die
Oil light
Unread post by born2die »
Hi sorry to ask yet another lame question but I have the orange oil warning light flash at me when i first start the car after it has been sat for more than 30 mins I have checked the oil level and it is fine up to the max mark on the dipstick. So am I being paranoid or is my oil sensor up the spout and if so where is it so I can replace it.
many thanks in advance b2d[8D][:I]
born2die
sorry forgot to say 1998 xantia activa
bxbodger
Unread post by bxbodger »
In a car that new it will normally be a faulty sensor, can't help with the location on a Xantia, though!!!
Unless, of course, its done starship mileage with no oil changes or maintenance......
born2die
nope garage did mot full belt oil etc change 2 days before I bought the car tis a 1998 withj 84000 miles on the clock. Bloody garage cheapskates only put enough oil in to make it reach the min mark[V]
AndersDK
Unread post by AndersDK »
Is the engine oil warning light ORANGE in a '98 Xantia Activa ???
x 1472
It's an oil level warning light that only flashes at start up if the level is low, and yes, it's orange! Prone to giving a false warning if the engine's only recently been shut down, or if the car is parked on any sort of slope. Often comes on (when it's supposed to I guess!) if the level is at or close to min as well. Well known to tell lies, so universally ignored. Use the good old fashioned dip stick!
ACTIVE8
x 6
Unread post by ACTIVE8 »
born2die
I too had the same problem, the oil level is correct, and yet it will intermittently come on !
Oscar Too
Unread post by Oscar Too »
This is because (I think) the sensor is right at the edge of the sump.
broomie
Unread post by broomie »
my Hdi is exactly teh same - park on a slope leave overnight - yellow light on - oil level on dipstick.
Kowalski
Unread post by Kowalski »
My TD does the same if I park it with one set of wheels on a pavement, i.e. at an angle.
drpau
Unread post by drpau »
my flashing oil light doesnt come on if dipstick level is at MAX but if its below that and has been parked on a kerb it will sometimes give it the flashing action! I dont like having it filled to MAX anyway. Thinking of the MAX level do you think they engineer a muppet factor into the MAX level so that MAX isnt the real MAX allowing muppets to overfill by a few millimetres dipstick-wise?
arry_b
Unread post by arry_b »
Muppet factor?
Oh yes.
Kowalski
The Xantia from Citroen, now with new Muppet tolerance factor.
ACTIVE8
x 6
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> The Xantia from Citroen, now with new Muppet tolerance factor. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Mahna Mahna [:D]
