It's been a while (C5 Adventure)
daviemck2006
x 496
Re: It's been a while (C5 Adventure)
Unread post by daviemck2006 »
Steves car did not have the correct wheels on it, it should have had alloys but had steels and trims. I think his tyres were 195/65x15 which was one size too small. I suspect that his wheels came off an lx trim c5 either a 1.8 petrol or a 2.0 90 rather than a 110 which his car is. That would have meant his wheels turning faster for a given speed so his speedo reading fast. Considering most speedos read slightly fast anyway, my leon says 33 when the sign coming into the town says 30, the xantia was about correct with those wheels on, but 3mph fast with the standards on.
Sent from my SM-T585 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 3302
I know that the legal requirement is that the speedos can have a tolerance one way (so they can read that you are travelling faster than you actually are), but no tolerance the other way (so it must NOT show slower than the actual speed). This assumes that everything on the car is how the manufacturer specified.
daviemck2006
x 496
I think that most of the cars i have owned since they put the sign that shows your actual speed up says 32 or 33 when it flashes 30. I know also that last week driving the activa down the road i was sitting at bang on 80 on the speedo and my wee garmin sat nav said 73. I think thats the way its supposed to be so if you were sticking tp 70 on the speedo you are well within the limit. If it was the other way everyone would be speeding! By the way i am not advocating that everyone drives at an indicated 80 lol
Peugeot boxer 2016
In the family
x 1996
Unread post by Stickyfinger »
daviemck2006 wrote: By the way i am not advocating that everyone drives at an indicated 80 lol
I am !..................... :)
x 3302
You would, but not all of us have a car that could out-corner a housefly in a room full of voracious bats!
daviemck2006
x 496
With decent grippy tyres, which it will get, the 205 wont be far behind the activa in the cornering stakes, but with 155x13 debica budget shyte ditchfinders its like being on castors. They were probably ok for the 84 year old lady that never drove out of Crewe!
Only 80 Sticky?
Peugeot boxer 2016
In the family
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Ladies, Ladies, Ladies......... :rofl2:
Changing the wheels has NOT changed the speedo, from the 'speed check' using the satnav, it's still reading about 10% under what's shown on the Satnav. In other words, going from 15's to 17's has made no difference whatsoever.
Now, the version of Lexia, I have (3.45) The only one that will talk to the car, won't let me change the wheel sizes, I'm getting a later version of Lexia sent to me, that I know does allow me to change wheel sizes, I'm hoping that this may help, but not being as technical as you rabble....... :oops: I'll have to wait and see
Steve
http://c6owners.org/index.php
x 3302
Sorry, Steve, I did not make my meaning clear. I was not thinking about the size of the wheels, but more the circumference of the tyres. If your C5 had been set up to have tyres with a circumference of 1 meter then (obviously) when the wheels rotate once the car will have moved by 1 meter. However, if larger tyres had been fitted (say, with a circumference of 1.1 meters) the car would move 1.1 meters per rotation, but the electronics would believe it had moved by 1 meter.
elma
x 287
Unread post by elma »
Dash speedos have to read at least 1.5% high by eu regulation.
Most are set a bit higher than this for a safety margin.
My Xantia for example is about 4% high from my (very rough) calculations.
So I do drive at 75mph, indicated, knowing I'm really doing 70mph and speed cameras do not go off.
x 3302
Yes, but Steve's speedo is reading LOW, showing 46MPH when he is actually travelling at 50MPH. That is the problem.
elma
x 287
What is the oem tyre size for his car?
x 3302
On MY C5 the label states 215/55/R16 (and my tyres match this). When I have compared the indicated speed to the Sat Nav speed I have found that they match (within 1MPH).
x 694
Unread post by Mandrake »
Has the car perhaps had a gearbox swap with a gearbox from a different car with a different final drive ratio ? That might also affect the reading depending on where the sensor is.
A lot of gearboxes come in different versions with different final drive ratio that are otherwise interchangeable.
x 3302
I believe (but I do NOT know) that the C5 uses the ABS system to calculate the speed, and not a drive from the gearbox itself. If I am right (and that is a big IF) the gearbox would not have any input to the speedometer of the C5.
If the speedometer itself is faulty it appears simple to replace the stepper motor, according to the instructions in the following link;
http://www.roadtestreports.co.uk/qanda/88959/
Trainman
(Donor 2018)
x 43
OK the tyres fitted to the car when I bought it were 195/65R15 the current wheels are 205/50 17
Steve
