Some say it's the secret of a happy marriageHell Razor5543 wrote: Seems to have worked, as they have been married for quite a while (although I cannot recall any mention of timescale).
Dean's Activa/XM/V6 and now Talbot blog
- x 8391
Re: Dean's Activa/XM blog
Deanxm
- x 87
More progress has been made, the engine was finished off after much faffing and ive nearly finished heavily re-building the engine management loom, this weekend the engine was cranked on its own starter for the first time in many years and apart from a bad earth due to my 99p shop jump leads it sounded fine.
IMG_3176 by Deanxm, on Flickr
IMG_3179 by Deanxm, on Flickr
The gearbox was stripped due to having some grit and muck in it after being stored for so long, given a good clean, new oil seals and a flushed through by turning the torque converter by hand while shifting through the gears, pumping the oil out, adding new oil and repeating untill clean red /dex2 was flowing.
IMG_3164 by Deanxm, on Flickr
IMG_3187 by Deanxm, on Flickr
IMG_3184 by Deanxm, on Flickr
IMG_3194 by Deanxm, on Flickr
IMG_3193 by Deanxm, on Flickr
IMG_3190 by Deanxm, on Flickr
IMG_3209 by Deanxm, on Flickr
IMG_3210 by Deanxm, on Flickr
Just finishing off some bits and bobs now so its ready for installation. The XM has its M.O.T booked as early as possible (21st March) to give a 13 month ticket, as soon as its had the M.O.T it will come straight home to start the engine removal process!.
D
IMG_3179 by Deanxm, on FlickrThe gearbox was stripped due to having some grit and muck in it after being stored for so long, given a good clean, new oil seals and a flushed through by turning the torque converter by hand while shifting through the gears, pumping the oil out, adding new oil and repeating untill clean red /dex2 was flowing.
IMG_3210 by Deanxm, on FlickrJust finishing off some bits and bobs now so its ready for installation. The XM has its M.O.T booked as early as possible (21st March) to give a 13 month ticket, as soon as its had the M.O.T it will come straight home to start the engine removal process!.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 1996
When are you ready to rebuild my spare ES9 V.6 then ? ....I can bring it over as I can get free tickets on the ferry
Deanxm
- x 87
..................i was wondering what my next project was going to be, im down your way tomorrow too
D
D
XM Prestige PRV6 92
- x 1996
Deanxm
- x 87
it would be nice to see a proper Activa and possibly engage in some Citroen nerd chat over a Coffee................how far into deepest darkest Somerset are you? i will be in Chard in the morning, not sure how long for but should be done by lunch.
XM Prestige PRV6 92
- x 1996
Between Frome and Shepton.....I have PM'ed you my number and PostCode
- x 8391
Very impressive work Dean
Looking very good indeed!
Deanxm
- x 87
Thanks Jim, I'm pleased with how its turned out, if it runs I will be ecstatic !
D
D
XM Prestige PRV6 92
- x 8391
Dean, I's sure it will run as sweet as a sweet thing
All the care and attention you've given it should make it the best PRV/HP18 on the planet I reckon
Deanxm
- x 87
your confidence is almost contagious Jim but then your not aware of the new pistons i made from old bean cans, Aldi beans too!
MK1 XM headlamps for those whom may be even slightly interested are pictured above, they are clear lenses with a plastic freznel, sort of. The outer lamp that is the indicator on a Xantia is the XM's side lights.
Morette headlamps are actually what looks like an ABS body and seperate cover which you paint to match not a steel frame as i thought, funny what the passing of time does to the grey matter! instead of one side light, a dipped beam and a high beam as fitted standard the Morette setup gives one dipped beam projector and two main beam units per side with a sidelight bulb built into each main beam unit
D
D
XM Prestige PRV6 92
- x 1996
As you know....that is interesting, clear dip side, flutes on main. So you could do the projector Hella lamp unit dip side without changing the lens (on a Mk1)
Nice to meet up today
Deanxm
- x 87
And im sure some one has, or is doing just that but for the life of me i cant remember who it is...............
Yes very good to see you, lovely Activa
D
D
XM Prestige PRV6 92
Deanxm
- x 87
And so, it begins.
IMG_0172 by Deanxm, on Flickr
I feel there should be some kind of fairwell ceremony.........
IMG_0171 by Deanxm, on Flickr
D
IMG_0172 by Deanxm, on FlickrI feel there should be some kind of fairwell ceremony.........
IMG_0171 by Deanxm, on FlickrD
XM Prestige PRV6 92
- x 8391
