C5 2002 handbrake problem
gentiii
hi i have problem with handbrake, after i release handbrake still stuck sometime i drive a lot and still stock, can somebody help me to fix this problem??
lexi
- x 134
Re: C5 2002 handbrake problem
Try freeing off the mechanism at the front calipers. They will be sticky. If they cannot be freed off you may need new calipers. I have freed mine off a few times now though. Check that the cables are moving freely in the tubes from caliper to handbrake lever. These can be an issue as well. It comes to all C5 owners
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
waynedance
- x 8
Just had new hand brake cables and tubes today. My cables were causing my calipers to stick.
Sent from my SM-T580 using Tapatalk
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
- x 1980
Disconnect the cables at the caliper, try and move the lever on the caliper, if sticking use a pair of grips and apply oil (start with a penetrating oil then use engine oil), lots of forward back movement. This will normally only be a temporary cure and a new caliper is the long term fix.
If the lever moves (relatively easily) try pulling on the cable to see if that is sticking....if it is then the only real solution is new tubes and cables due to internal corrosion. Replacing just the cable will be only a short term fix and is not cost effective as they will stick again, the corrosion will cause more problems even for a new cable.
- x 2943
Fairly regular treatment with penetrating oil followed by lube oil will make it a long term solution, mine have been ok for over two years now, I just set the suspension on high turn the wheel out reach under and spray takes a few minutes maybe once every couple of months.Stickyfinger wrote:Disconnect the cables at the caliper, try and move the lever on the caliper, if sticking use a pair of grips and apply oil (start with a penetrating oil then use engine oil), lots of forward back movement. This will normally only be a temporary cure and a new caliper is the long term fix.
- x 1980
Luck of the draw on the calipers then.....but worth the attempt
Clogzz
- x 40
Same here, a few squirts have kept me going for years.Gibbo2286 wrote: Fairly regular treatment with penetrating oil
- x 1453
Conditions where you are a bit less trying than they are over here thoughClogzz wrote:Same here, a few squirts have kept me going for years.Gibbo2286 wrote: Fairly regular treatment with penetrating oil
- x 1240
I did a quick bodge on one of mine that lasted for the rest of the time I had it. The plastic coating on the cables near the caliper end had failed and of course water had got in, I squirted copious amounts of oil into the cable through the gaps on several occasions and not only did it free off but it stayed freed off, I just used to squirt some more oil in when I serviced it.
