Hi all,
I have a 2010 C5 VTR+nav 2.0 hdi 160.
It has just developed poor cold starting, the glow plugs have been replaced with oe ones from main agent, however the poor/non start issue has continued.
On inspection by local garage it appears that fuel is being drawn back to the tank.
Consequently the fuel filter was replaced along with new seal, as were seals on pressure regulator as this appeared to be damp also. All was fine for 24 hours until starting this morning and same thing.
Got it going with a v quick spurt of easy start, any ideas ? (Fuel had also drained back so was hand primed again)
2010 C5 poor starting
JohnD
- x 72
Re: 2010 C5 poor starting
Is the starter motor turning at the required speed. I bought a new C5 in 2005 and after three years it began to be a reluctant cold starter. The dealer diagnosed that the starter wasn't turning sufficiently fast enough to raise the fuel pressure
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- x 3306
Good point, JohnD. I believe that the Injection ECU won't send fuel to the injectors if the RPM is below 800. My C5 started to take a few seconds before it would fire up. I replaced the starter motor with a reconditioned one from GSF (cost about £120, but I got back around £55 when I returned the old one in the packaging the recon had come in), and the engine then turned over so quickly I half expected the car would turn over as well!
- x 5674
Pretty much the same with mine.JohnD wrote:Is the starter motor turning at the required speed. I bought a new C5 in 2005 and after three years it began to be a reluctant cold starter. The dealer diagnosed that the starter wasn't turning sufficiently fast enough to raise the fuel pressure
Dommo
- x 20
Also had this issue with my 2007 2.2 C5, took some before and after videos which I think I posted on here.. I'll have a look
Dommo
- x 20
So apparently the videos weren't on here. Here's the before and after, the temperatures were similarly cold and the battery is new.
http://vid180.photobucket.com/albums/x2 ... 4pd4eo.mp4
http://vid180.photobucket.com/albums/x2 ... wc45ix.mp4
Kennyd90
- x 5
I had the same and mine has the same engine. Very slow starting and I replaced the starter motor and it's been starting on the first turn of the key. We had the same problem on our 206 2.0hdi dturbo and fitting a new starter motor fixed it.
C5owner
Update,
After replacing the Starter, Airflow meter, Fuel filter and housing, then battery. The fault was actually a leaking injector. Since then the car seems to be eating injector clamps..
