Citroen xantia drivers side engine mount
dcba12290
I am changing my top engine mounts on 1996 1.9 td xantia i removed the old one which was showing signs of perishing ordered new ones. However the new onecame without a spacer whereas the old one had one i can put the old spacer on the new one but seems to lift up the rubber guides to high wondering wether it should have a spacer in the first place. Has anyone got an exploded view of components for right hand mount for the 1.9 td ?..
- x 1999
dcba12290
Re: Citroen xantia drivers side engine mount
Thank you so much for that stickyfinger it has shown me what i needed definitely a spacer there number 14. The bizarre thing is looking at item 13 when mine was removed it was upside down which would hopefully explain the movement on pulling away but i cannot understand how this would have come about. If anyone has a xantia that they could try and get a photo of the mounting in place i would really appreciate it
Thanks Dave
Thanks Dave
