To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
It maybe worth checking there is a supply going to the stop solenoid as I had broken wire there.
Kenny
Help save my Xantia! AKA The immobiliser has made it break down.
KennyW
- x 164
Re: Help save my Xantia! AKA The immobiliser has made it break down.
C3 1.4 petrol (SWMBO)
ekjdm14
- x 261
Our ZX was bought as a non-runner with just the problem described above, although on ours the wire was broken as it came out of the actual solenoid. I actually cut away the pump armour in-situ to replace that, although it may be harder/not possible on a Bosch pump as ours was Lucas. Possibly worth a try though if you have a 4" grinder & either a dremel or cold chisel for the tight spots...
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
- x 8358
Very true Kenny and a good excuse to do the cambelt and water-pump at the same timeKennyW wrote:To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
MFH, If I can help with wiring diagrams then please let me know and I'll post them...
