Help save my Xantia! AKA The immobiliser has made it break down.
KennyW
x 165
Re: Help save my Xantia! AKA The immobiliser has made it break down.
Unread post by KennyW »
To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
It maybe worth checking there is a supply going to the stop solenoid as I had broken wire there.
Kenny
C3 1.4 petrol (SWMBO)
ekjdm14
x 281
Unread post by ekjdm14 »
Our ZX was bought as a non-runner with just the problem described above, although on ours the wire was broken as it came out of the actual solenoid. I actually cut away the pump armour in-situ to replace that, although it may be harder/not possible on a Bosch pump as ours was Lucas. Possibly worth a try though if you have a 4" grinder & either a dremel or cold chisel for the tight spots...
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
x 8465
KennyW wrote:To remove the pump and dearmour is not hard but a methodical approach and time you will have success.
Very true Kenny and a good excuse to do the cambelt and water-pump at the same time ;)
MFH, If I can help with wiring diagrams then please let me know and I'll post them...
