Lidl and Aldi Car accessories
x 3306
Re: Lidl and Aldi Car accessories
Well, my C5 has a gauge showing battery charge (well, it has the battery symbol), so maybe Citroen have a hankering for times gone by?
demag
x 102
Unread post by demag »
I think its only a matter of time before the fuel gauge disappears. You will have 2 LEDs, full and FILL UP NOW! :-)
Dave
x 3306
I know of somebody who made a modification to the fuel gauge system. His wife was always running out of fuel, and didn't seem to learn from her mistakes. After the modification she only ran out of fuel once.
What the mod did was to TELL people that the fuel was running out. When the gauge read 1/4 a voice said "You are beginning to run low on fuel". When it got into the red the voice said "You are running low on fuel". At the same time the warning light came on the voice said "You are going to run out of fuel". When the engine cut out the voice then said "I TOLD you that you were running low on fuel".
x 5674
My R11TXE Electronic used to do that and more. Insane :)
electronmirror
x 30
Unread post by electronmirror »
James (Hellrazor), if you are still looking for one of Lidl's battery chargers try their Wokingham branch on Molly Millars Lane. I bought one this evening, they had approx 30 of them on the shelf.
HTH
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
x 3306
Great, thanks for letting me know.
demag
x 102
I looked in our local store tonight but couldn't see any.
Sent from my Nexus 7 using Tapatalk
Dave
x 695
Unread post by Mandrake »
CitroJim wrote:Cars should still have ammeters in my opinion... One of the more useful gauges...
Or in the case of a GS - a voltmeter instead of an ammeter.
Which in some ways is a more useful indication of the state of a battery. An ammeter will tell you if a battery is charging - but how do you know if it needs charging ? It might already be fully topped up ?
I remember the GS's voltmeter gauge well - not labelled in volts but with colour coded ranges...
x 8391
Mandrake wrote:Which in some ways is a more useful indication of the state of a battery. An ammeter will tell you if a battery is charging - but how do you know if it needs charging ? It might already be fully topped up ?
That's very true Simon and in fact you can see when charging is good as you see the volts rising... Perfection would be an ammeter and a voltmeter!
Mandrake wrote:I remember the GS's voltmeter gauge well - not labelled in volts but with colour coded ranges...
A lot of up-market Brits back in the 60s and 70s had voltmeters and they had the coloured ranges but with vooltages marked on them too...
Smiths made the well-known and most popular classic one and it's still available today...
x 1487
I imagine the C5 one is a volt meter. Ammeters were on cars with Dynamos where current useage could easily exceed production - if it was in -ve territory for a long time you would know to give it some revs to get back into +ve territory.
I'm going to pop in our local one later - I'm hoping they've got some more of their screenwash additive in - I broke into my last bottle at the weekend.
x 2005
Unread post by Stickyfinger »
Just to clear things up in my mind.....
What is a good pattern of charge on a flat (but good) battery.
Low-med-high-float
or
High-med-low-float
x 1751
Many cars with alternators got ammeters too - eg Rover - but, having said that, the output from some of the early Lucas alternators wasn't a lot higher than their better dynamos. Service life was also pretty appalling, with a good trade in replacement internal voltage regulators. Big advantage of alternators was decent output at fairly low engine revs, something dynamos had difficulty providing.
Anyone remember Lucas RB340 current-voltage regulators, and the small chuck-like keys used to adjust them?
You're right about getting the most useful info from an ammeter: discharge was what to look out for!
Always did like the voltmeters with a "partial" scale (like Jim's 11-15 jobbie above). Did once construct one of those around a normal moving coil meter, for use in a caravan...
x 695
Stickyfinger wrote:Just to clear things up in my mind.....
Low-med-high-float
or
High-med-low-float
Depends how low it is to begin with.
The Lidl charger does pulse charging (rejuvenation) at a lower current if the voltage is very low, then goes to 3.8 amps constant then to 3 amps then to a 100mA float, each at a certain threshold voltage.
I don't have the book in front of me to see what the thresholds are but maybe someone else that has one can post that little graph from the book.
x 2005
Well that confirms the output pattern I have seen on the charger.
another question.
When attaching such a charger, should the battery be disconnected or does it not matter. (On a car with an ECU)
x 8391
white exec wrote:Anyone remember Lucas RB340 current-voltage regulators, and the small chuck-like keys used to adjust them?
Oh yes, many happy memories :) And happier ones still of the simple regulator installed on dynamo equipped Renault 4s. I had one weld its regulator contacts shut once and it led to a massive over-charge of the battery. I was only aware when I could smell acid!!! The battery was seething and the dynamo very hot indeed. The dynamo survived but not the battery which failed a few days after I managed to fix the regulator... I got home by disconnecting the dynamo and luckily the battery just lasted out. It happened near to where Stickyfinger now lives in 1978...
white exec wrote:Always did like the voltmeters with a "partial" scale (like Jim's 11-15 jobbie above). Did once construct one of those around a normal moving coil meter, for use in a caravan...
That's a very neat looking panel Chris. That really appeals to me...
I used to use my float charger in our caravan when mains was available... It now lives in my workshop...
