xantia brake problem
shahriartz
New User
Unread post by shahriartz »
hi,
my car has this problem and its really driving me crazy please help me
when i press the brake pedal the brake works just fine,but when i let go of the pedal,the brake cylinder in the wheels wont go back completely therefor all the time i driving the car brakes is engaging with wheels and forcing car to stop smoothly,like in the low slop roads the car will stop by it self,
x 6957
Re: xantia brake problem
I suspect your brake calipers may have siezed up (they do this with age). There are lots of topics on the forum here about Xantia brake calipers, just have a search. It woulld also help if you posted up your VIN as there are different types depending on model.
https://www.frenchcarforum.co.uk/forum/ ... hp?t=37415
elma
x 287
Unread post by elma »
It could also be worn discs or pads, dirty sliders, dirty callipers or some other obstruction.
Will you be trying to fix it yourself or taking the car to a mechanic?
Old-Guy
x 24
Unread post by Old-Guy »
The first thing to do is to find out whether the problem is with front of rear brakes. Your problem could easily be the old 'rear calliper corrosion' problem where corrosion between the steel suspension arm and the alloy cylinder forces them apart until the disc is scraping against the calliper body.
Copyright Old-Guy
Copyright Old-Guy
Copyright Old-Guy
Copyright Old-Guy
This is what the view from above should look like (with new disc and cleaned up calliper)
Copyright Old-Guy
Copyright Old-Guy
There is a fairly thorough wiki on replacing discs and pads which may help once you have worked out whether the problem is front or rear (of course you could be really unlucky and find both ends have a problem!
Let us know how you get on.
x 8378
If a brake calliper is binding, one very quick test is to feel the temperature of the wheel after a run of a few Km. The one that's binding will cause the wheel to be considerably warmer than the others...
It's easier to feel this when alloy wheels are fitted but with steel wheels, remove the trims before the test.
x 3306
Here is a good thread on what to look for (and how to fix it) on the rear brake callipers;
https://www.frenchcarforum.co.uk/forum/ ... 19&t=38467
elma
x 287
Don't know why but I read front brakes.
The rears do have a tendency lean as described above causing the brakes to stick on Xantias.
The fronts tend to warp easily as well which is the other possibility. Worth checking all 4 though as if the brakes haven't been serviced for a while it could be both sets.
x 2001
Unread post by Stickyfinger »
Or find a flat grass field with wet grass, you will soon find the binding one.
Old-Guy
x 24
Stickyfinger wrote:Or find a flat grass field with wet grass, you will soon find the binding one.
I think such a thing is unknown anywhere near Tehran.
x 2001
Ahh....had not clocked that :)....
And Welcome Shahriartz
x 5673
There are some green bits there and the temperature tonight is -1°C.
A workmate has just come back from Tunisia and shown me videos of all the snow there.
