C5 MK1 2.0 HDI '03. LDS low in tank.
samjmann
Unread post by samjmann »
Hi,
I had a 'return fluid pipe' separate in the NSF wheel arch. I didn't notice anything at all for months except a tiny amount of LDS visible in water when I washed the car. The pipe breakage was picked up in a MOT last November, I had the fault put right, the 'slightly different than normal noise' from the pump when the car 'wakes-up' after been parked then stopped. This noise returned yesterday, I had a look at the LDS tank and it was dry...
I've put 1 litre of LDS in, but there is still nothing showing on the marker in the filler. I'm fairly sure that there is no leak, (not on the high pressure side anyway) as the ride and pump action are as normal. How much does it take to fill/part fill the system? I wasn't charged for any LDS when the return pipe was replaced, so I can only assume the level was low then as well...
I've had three suspension leaks on the car in the past, and I now recognise what LDS and water look like on concrete as apposed to engine oil and water! At £10 a litre for Total LDS I'm a bit cautious about just poring more and more of the stuff in.
Is it OK to top the level up or does the tank have to pressurised? When I release the cap there is pressure released.
Thank you in advance for any advice. SJM.
x 3283
Re: C5 MK1 2.0 HDI '03. LDS low in tank.
The way to check the level (and to fill the tank, if required) is with the car bottomed out. Take the cap off (yes, it is normal for there to be a little bit of pressure), and then take a look. Ideally there should be LDS between the upper and lower markers (I have attached a photo, to illustrate). If there is not you will need to add some more.
Reason: Image tags
samjmann
Thanks Hell Razor5543,
I didn't know the suspension had to be set to low to fill the tank. I'll have a careful look under the car in the morning before I set off, just hoping there is no leaks. The odd noise from the pump is perhaps it priming when the level is low. Despite putting a litre in there appears to be nothing in the tank.
Cheers SJM.
lexi
x 134
Unread post by lexi »
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 6961
samjmann wrote:Thanks Hell Razor5543,
Cheers SJM.
Well it must of been low in that case. Clean up any LDS around the tank and surrounding areas, top up the reservoir to the marks whilst car is on lowest suspension setting. Try and place some cardboard or similar on the ground under the front area and leave overnight, to try and identify where it is leaking from.
dnsey
x 19
Unread post by dnsey »
It's possible that a sphere membrane has ruptured, and some of the fluid is now filling the gas cavity.
Is the suspension still soft on all four corners?
samjmann
Thanks again for the replies,
The car has been fine since I put 1.75 Litres of LDS into the system..! There was a leak on the return side on the NSF return pipe in the wheel arch. I had this put right last November, however as far as I know no LDS was added to the system! I wasn't charged for any. I had noticed an odd spot of LDS on the driveway last year, going back as far as last summer, but had not been able to trace it!
Having said this, this afternoon, the suspension suddenly went rock hard on all four wheels. This happened after going down a very steep hill and then having to go over numerous speed cushions. I stopped the car and cycled the suspension a few times from bottom to top and all appeared OK. The car is now driving normally, but I'll do a check on the LDS again tomorrow. I've read on another post on the forum that the system may need to be bled to allow air to escape. As the return pipe from the NSF sphere was for months not connected; after connecting up now there must be air in the system -I think! I will keep a close check for any leaks
When the pump starts, sometimes there is a slight squeal from it after which it runs quietly. Other times, it will pump quietly without the initial squeal.
Is it possible that the return is full of air locks?
BTW, Lexi that's a good price for the LDS. I paid £9.18 trade inc VAT from a national motor factors.
Cheers, SJM
