xantia clutch slave cylinder
holmedog
x 5
Re: xantia clutch slave cylinder
Unread post by holmedog »
Thanks very much Jim. Was not looking forward to having to take the engine out again. And also the cost of a new complete kit.
Sent from my GT-I8200N using Tapatalk
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
x 8204
There's always a way round these things ;)
x 8204
The replacement slave is now on its way to you ;)
Posted this morning... First class so maybe it'll be with you tomorrow...
superloopy
x 19
Unread post by superloopy »
Are these slave cylinders the same across all hydraulically operated setups?
Sent from my LG-D855 using Tapatalk
Mike
x 8204
xantiamanic wrote:Are these slave cylinders the same across all hydraulically operated setups?
Xantias, yes... There are differences with other models... Some models have slaves with bleed nipples on them and ones that may outwardly look similar have different pushrod lengths...
holmedog
x 5
Sorry for late reply but thanks Jim. Would of replied sooner but left my phone at my mates.
x 1457
I'd still want to know what caused it to fail.... if you shove the new one in there, and then welly the clutch pedal and it's seized somewhere(as it looks like the slave has ripped itself out of the bellhousing), then bang, another slave bites the dust....
x 8204
RichardW wrote:I'd still want to know what caused it to fail.... if you shove the new one in there, and then welly the clutch pedal and it's seized somewhere(as it looks like the slave has ripped itself out of the bellhousing), then bang, another slave bites the dust....
One cause of this failure, Richard, as I have found to my cost in the past, is that it's easy to insert the slave with the pushrod 'on the cock' and it goes to the side of the cup on the release arm in free air rather than sitting in the cup. Then, when first operated the slave pushes into nothing and blows itself apart... The pushrod has a natural tendency to not line up with the cup so you have to be very aware of this... The weight of the pushrod causes it to down and out of good alignment as it is inserted.
A brand-new slave has a special tripod mount to hold the pushrod in correct alignment during insertion. This tripod then breaks on first use. Often the remains of the tripod can be seen on a used slave.
x 1751
A good few clutch slave cylinders used to be fitted with a simple tension spring that kept the actuating arm gently pulled toward the slave cylinder body, and the pushrod centred in the cups, so it couldn't drop out of place.
x 8204
white exec wrote:A good few clutch slave cylinders used to be fitted with a simple tension spring that kept the actuating arm gently pulled toward the slave cylinder body, and the pushrod centred in the cups, so it couldn't drop out of place.
That's the same role the 'tripod' plays Chris...
You can just see the remains of one in this picture:
x 1457
I was thinking that the old slave looked like the retaining lugs had broken off - but looking at that pick maybe not; perhaps what has broken off is the remains of tripod? Does this normally happen if the plunger is ejected? Another thought that crossed my mind is that perhaps it was engaged on those tripod lugs rather than the proper ones, allowing it to be pushed back out of the box.
x 8204
RichardW wrote:I was thinking that the old slave looked like the retaining lugs had broken off -
I think that still Richard... The 'tripod' is very thin plastic and all you can see of the remains in the picture above is the ring around the pushrod and bits of the 'legs' It is very fragile and designed to break easily..
Holmdog's lugs don't look at all right to me.. The lugs form bayonets and it can be biblically tight and hard to remove.. It is further tensioned by big crinkle washer which is just visible in my picture.
holmedog
x 5
Thanks for the slave Jim. In my pictures the lugs have completely disintegrated.
x 8204
No worries, pleased it arrived safely and I trust it'll help resolve your problems....
holmedog
x 5
Everything crossed doing clutch master/slave cylinder and have sourced a pipe for the hydraulic system.
Really need to get this car done now.
