Tappety 406 hdi
xsaras4ever
x 44
Tappety 406 hdi
Unread post by xsaras4ever »
Hello to all , we have been having BSI problems with the 406 (110 hdi) which are in another posting and they have been now worked-around, just yesterday.
However, this morning we started the 406 - all iced up hard - started straight away.
Turned on heaters and screens to de-ice, popped indoors for about 15 mins for a cuppa.
Back out to 406 and its sounding tappety - we were hoping it was just a dropped spanner clinking against the motor - but no.
Rev it and its gone.
The car still drives great.
Tappety at 800rpm, disappears at 950 rpm.
Also disappears after about 15 mins of normal driving.
Cracked cam bucket maybe (is that the correct term ?)
All fluids are present and correct.
Any ideas ?
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 2005
Re: Tappety 406 hdi
Unread post by Stickyfinger »
1st thing I would do (if it is not self destructing and really loud) is to use this...
harryp
(Donor 2022)
x 73
Re: Tappety 406 hdi
Unread post by harryp »
... and check the oil pressure at 800rpm. Could be not high enough; used to be common on worn petrol engines!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 1751
Re: Tappety 406 hdi
If it only does this with a very cold engine, and it disappears, it could just be a valve/tappet clearance a bit on the wide side, showing up when very cold.
Clean and correct oil filter?
Grade of oil too thin?
Oil pressure relief valve (assuming there is one) stuck slightly open?
xsaras4ever
x 44
Re: Tappety 406 hdi
Hello to all , will try the product - thanks.
Also , where is the pressure relief valve ?
Yep , good filters and correct grade of oil.
Its Dad's car and a pain in the butt really. He is only here in France for 2 weeks so am tempted to set the idle at 1000rpm and get through the next 2 weeks.
Is that possible with PP2000 ?
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 1942
Re: Tappety 406 hdi
AFAIK it's not possible to alter tickover speed on anything in the last 15 years or more. This is fixed and monitored by the engine ECU or similar.
x 1487
Re: Tappety 406 hdi
Have a look at the crank pulley - when this fails it can make sorts of odd noises at idle. First sign is usually that it is covered in rust.
xsaras4ever
x 44
Re: Tappety 406 hdi
Hello to all - the old git is gone home now and the 406 didn't explode.
Noisy cold and hot now - took the oil filler off and its coming from in there - camshaft off we reckon to have a look - but at least no hurry now.
Will post an update - sometime in the distant future..............
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
xsaras4ever
x 44
Tappety sounding 406 hdi - SOLVED
Hello to all , we left this car alone for a few months.
We started it and did a proper investigation - without the pressure of needing the car to be used immediately.
It turned out to be the crank pulley - fitted a new one (52 euros) and its all back to normal.
Well done RichardW :-D :-D :-D
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
ekjdm14
x 263
Re: Tappety 406 hdi
Unread post by ekjdm14 »
Brilliant, nice to hear the conclusion to a story & especially so when it was a cheap fix :)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
