Strange thing, my 94 xantia 1.8 heater blows cool at idle but if I raise the revs it gets warmer?
Failing water pump or something else?
Xantia Heater
tim leech
- x 12
Xantia Heater
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
chinkostu
- x 30
Re: Xantia Heater
I would think it'd be a weak pump, as usually the issue is the car overheating when idle and cool when driving! either that or thermostat stuck open maybe?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
tim leech
- x 12
Re: Xantia Heater
Haven't driven it for years but it did run hot!
Worth changing the thermostat?
- x 8368
Re: Xantia Heater
I'd say low coolant and resultant intermittent airlocks...
I'd check coolant level and then bleed the system thoroughly Tim...
In thinking about it, given that the car has not run for a while I'd also give the coolant a change/flush and refill with nice fresh stuff...
tim leech
- x 12
Re: Xantia Heater
Will do, although it had a new radiator just before it was parked up
- x 8368
Re: Xantia Heater
Maybe when fitted the fitter did not bleed properly perhaps?tim leech wrote:Will do, although it had a new radiator just before it was parked up
tim leech
- x 12
tim leech
- x 12
Re: Xantia Heater
I have bled it a few times but maybe it needs a flush
- x 8368
Re: Xantia Heater
I would...tim leech wrote:I have bled it a few times but maybe it needs a flush
Old-Guy
- x 24
Re: Xantia Heater
Failing that, check the thermostat; they don't last even as long as cambelts. I've put 3 or 4 new ones in the Green Lady in the course of 10 years (the first within a few months of buying her), though IIRC they all failed to open fully, rather than not closing.
