C2 crankshaft speed sensor
Ramshackle
Hi I am trying to change the crankshaft speed sensor on my C2 but am finding it very diffecult to remove. Is there any special nack or method?
- x 1044
Re: C2 crankshaft speed sensor
What engine is fitted to your car ?
Ramshackle
Hi Wheeler it is a 1.4 litre SOHC 8 valve HDi. Reg SV56BXE.
- x 1044
If I remember right on the HDi you need to remove the crank pulley to get the sensor off. Is it the crank pulley that's stopping it ?
Ramshackle
The car has, or did have a/c. There appears to be a plate immediately behind the crank pulley, and it's a combination of the plate and pulley that seems to be stopping me fitting a new sensor. I managed to get the old one out but only after drilling out the top plastic locating lug. The crank pulley is larger than other ones shown in the Haynes manual, but I think you are right and I will have to remove the pulley. Thank you for your help. Have a good New Year.
