For my sins.
Richard_C
(Donor 2026)
x 223
Re: For my sins.
Unread post by Richard_C »
I see that A16 BXC is available from DVLA for £250 - after all its A 1.6 BX Citroen :-)
Richard_C
demag
x 102
Re: For my sins.
Unread post by demag »
[emoji3]
Sent from my Nexus 7 using Tapatalk
Dave
ekjdm14
x 256
Re: For my sins.
Unread post by ekjdm14 »
white exec wrote:
Richard_C wrote:
ekjdm14 wrote:Cock & Trumpet, the pub that was on the same site.
Gosh. :shock: I wonder what the pub sign looked like???? :roll:
Just as intriguing as The Tart'n'Blanket . . .
When on earth did I write that? :shock: have I fallen victim to Anonymous hackers perhaps? :?
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
demag
x 102
Re: For my sins.
Does anyone watch Car SOS? They were rebuilding a Nissan Skyline in the last episode I saw. Fuzz Townsend was replacing the cambelt. He carefully cut the old one in the middle with a Stanley knife all the way round so in effect he'd got two belts side by side. Then he slackened the tension slightly and removed the outside half of the belt. He slid the new belt on and then cut the rest of the old belt off. Re-tensioned everything and didn't have to time the engine or lock any sprockets up. I've never seen that done before.[emoji3]
Dave
van ordinaire
(Donor 2017)
x 402
Re: For my sins.
Maybe on a Skyline in a TV studio - but not a Citroen in the real world.
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
Dennismenace92
Re: For my sins.
Unread post by Dennismenace92 »
demag wrote: 15 Dec 2016, 15:14 A couple of years ago I became the custodian of a quite rare Bx. It is a Tgs automatic, I think there are eight on the road presently. I drove it back from Bristol to home and for an old car in need of some tlc it went reasonably well. Over the ensuing months I have picked away at it and got quite a few jobs done. I didn't mot it last year because I had that much going on after I retired it would have been pointless. However I managed to repair/replace/rebuild the carb, Speedo, fuel pump, time the ignition which was mysteriously retarded, start changing the gearbox Dexron ll and had all the spheres checked and recharged plus I repaired some odd electrical faults.
Then.... I had to move it on Monday because we are having the drive block paved. It started and stood up as it always does and just as I was reversing off the drive down it went! Not nowww! I got it moved onto the chapel carpark next door but knew it couldn't stay there. So popped over to see Paul the indie and explained my dilemma. Normally a grumpy bugger he enthused about it saying he hadn't seen one for years. So he gave me the number of a friendly recovery man, Breakdown Brian! [emoji3] Well I rang him and he seemed a really nice chap. He came over yesterday and turned up in a beaver tail Transit. I thought there's no way it will go on that but you know it went on as sweet as a nut with no suspension and no pas. He made it look easy, oh and he looked just like Father Christmas.[emoji3]
This morning I had a call from Paul the indie. I was expecting the worst. "Do you know" he said, "this is a lovely little car, we've checked it all over and the leak is an easy fix and I reckon it would go through an MOT with a little work".
I knew it wanted strut returns but I have loads of spares for it including two genuine returns. So he's going to do the few jobs and put an MOT on it for Monday. Then after New Year he will do the cambelt as well.
Hi mate, I have become the owner of this BX. Wondered if you can tell me more about it.
Dennis
x 8298
Re: For my sins.
Dennis, congratulations on becoming the new owner of this BX :D
Do please keep us updated on your adventures with it ;)
I'm not so far from you and will be looking forward to seeing you and it at some local shows...
x 2316
Re: For my sins.
Unread post by MattBLancs »
demag wrote: 23 Jan 2017, 01:48 Does anyone watch Car SOS? They were rebuilding a Nissan Skyline in the last episode I saw. Fuzz Townsend was replacing the cambelt. He carefully cut the old one in the middle with a Stanley knife all the way round so in effect he'd got two belts side by side. Then he slackened the tension slightly and removed the outside half of the belt. He slid the new belt on and then cut the rest of the old belt off. Re-tensioned everything and didn't have to time the engine or lock any sprockets up. I've never seen that done before.[emoji3]
I've heard of this technique but never seen the point, if you're doing it properly then water pump and tensioner all will be swapped as part of the task.
Wouldn't work on my C5 with its floating crank pulley even if you left the tensioner/ water pump as is!
x 8298
Re: For my sins.
And the tension, if the car has a manually adjusted tensioner, must be reset... No ifs or buts about it... To do a cambelt other than properly is a bodge of the highest order and carries huge risks...
And as you say Matt, if you don't do the water pump and tensioner at the same time you'll find you'll soon have to... Been there - once... And once was enough...
This won't work on a TU engine due to the guide flanges on the crank sprocket...
x 2316
Re: For my sins.
I have done a "belt only change" on my car in the past, but only my second change on that car as I used a good quality full belt kit 1st time so knew the tensioner/idler was decent quality. Still checked they ran smoothly and didn't come a cropper in the second change.
Mind you this was an XUD9TE and was changing at 50,000 miles (think official interval is 72,000 and Haynes suggests halving it to 36,000. So I went in the middle). Don't think I'd do the same belt only for a DV6 with the 125,000 - 150,000 mile intervals!
