Courtesy light door switches?
HDI
x 7
Unread post by HDI »
Where are they located? They aren't visible so must be concealed in the lock mech somewhere. The one on the drivers door has stopped working, the lights work normally off the other doors.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
van ordinaire
(Donor 2017)
x 402
Re: Courtesy light door switches?
My Cadillac experience tells me "modern" cars don't have them!
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
x 8325
On an S2 Xantia they're effectively inside the locking mechanisms in the doors. S1 Xantias retain traditional courtesy light switches...
Normally the integrated switches in the S2 are very reliable... I'd firstly check if the wiring to it is intact. S2 Xantias are notorious for snapping wires in the 'concertina' between door and A Pillar. The driver's door suffers more as it's usually the most frequently used...
If you do need to get at the switch you'll need to remove the central locking mechanism from the door and crack it open by drilling out rivets.. It' not really made to be serviceable :(
HDI
x 7
Typical, nothings simple anymore! Thanks Jim.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
xf1ref
x 12
Unread post by xf1ref »
At Xantia mk2 the front door mechanism contains two switches, one is for courtesy light and one is for detection if the door is completely closed.
Like CitroJim said you have to drill out a rivet...if I remember correctly is just one rivet.
In the picture below is the mechanism from rear door...it contains only one switch for courtesy light.
x 8325
It's great to see a picture of this :D Thanks for posting it XF1!
beko1987
x 16
Unread post by beko1987 »
Damn I was hoping this was about the S1, my drivers door stopped turning the light on and off the other week, passenger door one is looking very tatty too.
Good luck! On my old ZX it had a door open display on the dash and the passenger door always showed as open unless it was raining/very damp. Apparently all that was built into the door lock mechanism so I did the sensible thing and just ignored it!
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
x 8325
S1 has conventional courtesy light switches Sam ;) They do suffer the usual problems and they are standard PSA items...
HDI
x 7
Thanks for that image xf1ref. I've wiggled the door pillar to door wiring but no difference. The light works when opened with the remote fob, just not with the door only. So I will need to delve further.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1751
HDI wrote: The light works when opened with the remote fob, just not with the door only.
I'm guessing that remote fob will bring the unlock/lock motor into operation, while just opening the door will not, as the door handle "by-passes" the motor mechanism. So ??? courtesy light switch fault resides inside the motor unit.
Just guessing.
HDI
x 7
That is more than likely the issue. I have an aversion to removing trim though, so my motivation is low for sorting this!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
