207sw fuel filter
pikecrazy
207sw fuel filter
Unread post by pikecrazy »
My Partner has a 1.4 207sw 16v petrol 57 plate she's always running the fuel down and when i drove it the other day it seems to have an intermittent miss as in lack of fuel.
No fault codes so could it be the fuel filter ?
And if so where is the location please.......
Phil
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
spider
x 77
Re: 207sw fuel filter
Unread post by spider »
Looking at both the TU and VT based engines (As I suspected anyway) they do not appear to have one, not in the sense of one in the pipeline.
This is a bit like later 206 where they deleted the external petrol filter (used to live near the tank area on the offside)
The 'filter' is actually part of the pump / level sender unit in the tank. I'm unsure how much disassembly is needed to extract said filter but its not actually listed as a separate part anyway that I see, its designed to last the life of the car usually.
Having said this on another make I dismantled one completely (it was a royal pain as there were one way valves and springs in it (!)) to clean it out and put it together again.
I think if there was a fuel supply issue though I'd expect a code present. Are you basing this on the 'K' light not being on or did you scan for codes ? :)
Andy.
pikecrazy
spider wrote: I think if there was a fuel supply issue though I'd expect a code present. Are you basing this on the 'K' light not being on or did you scan for codes ? :)
No K light and haven't scanned for codes as i don't have a reader !
spider
x 77
I'd be tempted to try to have the codes read if you can.
Simply as some faults do not cause the light to come on, two random examples of this (note: these are not your issue here, well very unlikely!) are EGR valve and MAF issues, these do not cause the light to appear unless there's a serious issue like a short in the sensor itself, just providing this as a 'not all causes the light' example.
Are you not able to locate anyone who could scan it for you ? , ideally cheaply or free would be better.
Andy.
pikecrazy
spider wrote:I'd be tempted to try to have the codes read if you can.
Surprise surprise....engine management lights on, have changed one of the coil packs and seems to be sorted now !
Thanks for your help will try and locate a reader ....
spider
x 77
You're welcome. :)
Andy.
