guys
where is the temperature sensor , its suppose to be under the mirror there's nothing under the rhs mirror is under the left mirror ? how do replace it because its showing the wrong temperature ?
thanks in advance
citroen synergie 2.0hdi 2001 temperature sensor
shahidocean
- x 6
- x 6957
Re: citroen synergie 2.0hdi 2001 temperature sensor
Do you have your VIN handy?
- x 6957
For a right hand drive, it is under the passenger mirror. It is a small nipple on the underside. Post you VIN if you want the part number.
shahidocean
- x 6
- x 6957
The part number for the exterior temp sensor is 6445 F9 (item 6 on the diagram) They are usually fitted on the inside of the mirror and the little nipple pokes out from the underside of the mirror housing. Unfortunately, there are no further diagrams showing the disassembly of the mirror.
