BX question......
Dave Bamber
BX question......
When were coated brake/suspension pipes first used on the BX?
- x 1439
Around 1992 IIRC. If you're changing, better to use Kunifer instead, as it never rots, and is easier to get in. Coated pipes are not a panacea though - the rear curly brake pipes on my old Xantia rotted through in 9 years, despite being coated (but then the car did spend its first 3 years in inverness I suppose...!)
nick
vanny
I'd go for a little before '92. My current BX is a '91 and its got plastics, its a J-reg and as i understand it ALL the j-reg had plastics. I'd guess it came in about the time of all the main changes, so around the late '90 early '91 mark, so H-reg ish, but its a bit of a lottery which does and doesnt have the plastics!
bxbodger
Mine was built in May 1989 according to its RP, and they were onprotected- I know because I had to change 'em all from the front backwards[xx(]!!!!!!!!
Mines on a G plate, <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I think it was earlier than that, sometime in 1990.
I can remember test driving a January '91 H reg BX estate that had had all plastic coated pipes from new.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
It must have been about the middle to end of 1990, then.
- x 1439
Dave Bamber
Jon
