I think that Rapid Electronics offer 14v capless, in a couple of wattages.
You can also wedge one of these little lamps in a piece of pvc sleeving, or a sleeved grommet (sorry, Gibbo) to insert it into its socket, and then twist off the tubular 'holder'.
Replacing Xantia Instrument Illumination Bulbs
- x 1746
Re: Replacing Xantia Instrument Illumination Bulbs
- x 8436
That's doing it the hard way JamesJames the HellRazor wrote:It's been a mighty long time since I've changes an S1 heater panel lamp but, IIRC, last time I managed it quite easily by accessing it through the radio aperture and removed - and fitted - the new lamp with the aid of a small socket on the end of a small ¼" extension bar. You wedge the end of the captive lamp in the socket and feel around for where it goes !
I think I'd better do that part of the guide sooner rather than later...
beko1987
- x 16
Superb timing, this is a job I need to do next year, as well as the heater bulbs (entire bottom is unlit on mine!). Doesn't look too tricky looking at your pictures
A how to for removing the heater controls would be good, the speed control knob on mine snapped off (still adjustable with a small screwdriver), I had a brief go at removing it but could not work it out.
But before doing either of those jobs, it A - needs to warm up a bit and B - I need glue as my dash innards are a bit broken around the radio and top row of buttons!
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
superloopy
- x 19
My heater controls are totally screwed. The sliders dont seem to control anything behind the panel so i'm guessing the wires are knackered. A 'howto' remove heater panel would certainly complement this bulb repkacement procedure. I'm guessing it's eadiet to just dip into the dash the once and kill two birds with the proverbial one stone?
Sent from my LG-D855 using Tapatalk
Mike
- x 8436
Mike, that needs a bit of deeper diagnosis... Start a new thread and then we can get it sorted for youxantiamanic wrote:My heater controls are totally screwed. The sliders dont seem to control anything behind the panel so i'm guessing the wires are knackered.
For both of you, I'll do a little how-to on how to pull out the panel... It's made a little trickier as there are two bowden cables involved...beko1987 wrote: A how to for removing the heater controls would be good, the speed control knob on mine snapped off (still adjustable with a small screwdriver), I had a brief go at removing it but could not work it out.
Too cold? I've bee out doing a cambelt today!!!
- x 2006
I am happy to put mine into the position of being photographed for this Jim
Happy to click away whilst you do the work
....short video sections on the tricky parts maybe ?
Lights --- Camera -- ACTION, break a leg darlings
- x 8436
ExcellentStickyfinger wrote:I am happy to put mine into the position of being photographed for this Jim
Happy to click away whilst you do the work....short video sections on the tricky parts maybe ?
- x 2006
Hey...BONUS for me....and we can do the work in the garage
- x 8436
That's a massive BONUS for meStickyfinger wrote:and we can do the work in the garage
superloopy
- x 19
Whats a bowden cable then or was it just predictive textspeak for 'broken'?
Mike
- x 2006
a pre stretched steel cable within a self lubricating re-enforced protective sleeve/cable guide.
- x 8436
Think of a throttle cable, a choke cable, a speedo cable, a clutch cable or a brake cable on a bike. They are all examples of Bowden cables...xantiamanic wrote:Whats a bowden cable then or was it just predictive textspeak for 'broken'?
Jaf
- x 42
Thanks for this guide Jim. Finally got to Fred's bulbs, mainly for the engine temperature bulb which hasn't worked for 10 years. Only to find the bulbs I bought are terrible quality. Sigh. The couple I got to work show how dull the original bulbs have become though. Have ordered some more.
I notice in your photos that your electric door mirror switch is the same as mine. I always thought mine was aftermarket as it doesn't match very well!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 8436
Jaf wrote: I notice in your photos that your electric door mirror switch is the same as mine. I always thought mine was aftermarket as it doesn't match very well!
No, that's the standard for low-specification Xantias Jaf... Seems a most odd way of doing it to me!
Delighted my guide helped swap your bulbs... Excellent!
