Can anyone please tell me the symptoms (more noise, loss of power etc) of a diesel injection pump with the wrong timing (too far advanced or retarded)
Thanks.
diesel pump timing
sooty
I've only experienced an Diesel engine out of timing some years ago. From memory if it's retarded you'll get white smoke and a noisey clatter sound and if it's advanced you'll get pale blue smoke and again clattery. In both cases you will lose power, a danger is if is too far either way, out of timing you stand a good chance of the Pistons hitting the Valves. Your best bet would have peep in the Haynes manual for Diesels next time you visit a shop that sells them, if you don't want to buy one.
Sooty <img src=icon_smile_blackeye.gif border=0 align=middle>
Dave Burns
- x 3
There's no chance of valves and pistons coming together because of pump timing errors, only when there are camshaft/crankshaft timing errors will this happen.
The diesel knock will increase and become more pronounced with timing too far advanced, it will also be reduced when the timing is retarded, this may be accompanied by increased smoke as the optimum burn time and ignition temperature may be reduced, white smoke may aslo be produced when starting from cold.
Performance will suffer if timing is too far one way or the other.
Dave
Dave
jmd
rcflyers
Thanks all,
I have 2 rover 218 cars, one has the citroen 1.9 non turbo engine, the other has the citroen 1.7 turbo diesel engine.
They are both noisy (diesel clatter) when cold, but when warm, the 1.9 quietens down, but the 1.7 is still very clattery at idle and under load. also the 1.7 has no bottom end power until the turbo starts boosting. the 1.9 has a lot more bottom end power, but obviously is not as lively at the top end due to lack of a turbo.
I haven't noticed either car emit black, blue or white smoke.
The air filter is OK and the new fuel filter i fitted to the 1.7 has made no difference.
Does it sound like an injector/pump timing fault?
Dave Burns
- x 3
JohnD
- x 72
rcflyers
sooty
JohnD
- x 72
rcflyers
DLM
IIRC modern low-sulphur diesel is lacking in lubrication properties compared to previous diesel fuel. This lubriation is important for correct and long-term operation of the diesel pump and for loosening & burning deposits from the injectors. In France this is overcome by including a proportion of biodiesel (10%?)in the fuel, which has better lubrication properties.
In the UK it's therefore a sensible precaution to add some form of additive to do this - even if it's only every few tankfuls.
