No sound from indicators - [SOLVED]
x 6956
Re: No sound from indicators
osx wrote:Thanks. I would be really surprised if the sound came back after activating the AM waveband (had deactivated it last year ;-))
Just curious - is there a reason why you would want to deactivate the AM as opposed to just not listening to it - or am I missing something here? :?
osx
(Donor 2022)
x 15
Unread post by osx »
Avoiding an extra step when going around modes and freeing some memory. I do the same with my PC - remove all keyboard layouts except from ones i use.
C5 X7 Exclusive 2.0 HDi Auto
osx
(Donor 2022)
x 15
Can't seen to be able to adjust audio volume. The level on the screen changes but not the speaker output.
x 6956
osx wrote:Can't seen to be able to adjust audio volume. The level on the screen changes but not the speaker output.
Nik - do you have wifi access on your laptop whilst connected up to the car? I'm thinking it will be a lot easier to dial in and check out the settings directly, whilst being able to refer to resources here.
If so, download and install Teamviewer 11 from here (it is free for private use) and let me know if you want to proceed. I can't really see any easy way to do this - I have different vehicle options for a start so cannot compare your car with mine - but I may be able to check my configuration tables against your spec and see if the options seem right.
https://www.teamviewer.com/en/download/windows/
osx
(Donor 2022)
x 15
Can do this over the weekend if it's convenient. Haven't used this software before so will install it tonight and have a quick play.
x 6956
There's nothing to it Nik - once installed and you are connected to the internet, you just provide me with your unique ID number, and when we are ready to connect, just email me the pass code. The pass code changes each time the software is launched for security. That's it. We can then chat via the on-screen message system.
In the meantime, I will run off some notes for your car and go through what I think your options should be coded to, based on your spec. It would help also if you could think back and try to remember what other sections you may have gone into.
osx
(Donor 2022)
x 15
Managed to fix the sound level adjustment by changing Hi Fi amplifier settings from Absent + Multiplexed to Absent + Standard
Sound from parking sensors is slightly different but at least it works.
I think I will end up taking it to the dealer for the 100k service and ask if they can update the firmware as they will be running (and charging) for a diagnostic anyway.
x 6956
Ok thanks for letting me know, I'll stop the work I am doing on cross referencing options with my car in that case. The HIFI Amp configuration data table was amongst those that I had completed.
I am pleased you have returned it so somewhere nearer to what it should be. Whilst you are at the garage you can query the phone issue you were trying to resolve initially.
osx
(Donor 2022)
x 15
Fixed after a year!!! Changing the circled option from "Yes" to "No" did the trick.
x 6956
Re: No sound from indicators - [SOLVED]
Yes, that's not a valid function for an C5 X7 - I've had a similar issue with another member who changed several of these options and his car lit up light a Christmas Tree as none of these are applicable to this model.
osx
(Donor 2022)
x 15
Makes you wonder what does automatic activation of lights have to do with indicator sound :)
What is the "Light Pack" unit by the way?
x 6956
Because they are conflicting options as they are meant to be set for vehicles with a different head unit that controls some features differently to the X7 (including Peugeot models). Some vehicles control some options via the multifunction screen where the X7 has a separate instrument panel secondary display to control some of these.
As for the ‘Light Pack’, that should be the Ambient lighting system.
