BE3 gearbox parts distributers?
romie
Unread post by romie »
Hey, I'm after a BE3 fifth gear and its synchro.
Other than the main dealer, I'm finding it difficult to find other part sources.
Any links?
Couldn't find anything on ebay
http://www.onestopgearboxshop.com couldn't help.
Citroen part numbers:
Fifth gear
DRIVE GEAR
2333 43
01 5EME 47DTS (47X31)
LE-2006
Substitute part number:
2344E9
Synchro
MANUAL GEAR-BOX SYNCHRONIZER
2388 04
01 5EME 22X24
LE-2015
238832
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
x 8427
Re: BE3 gearbox parts distributers?
A scrap gearbox from a similar vehicle is still your best answer Romie ;)
Chances are the 5th gear assemblies will be good; it's not usual for them to wear a great deal... It's third gear that normally goes...
romie
CitroJim wrote:A scrap gearbox from a similar vehicle is still your best answer Romie ;)
Hi, hmm.
Just the fifth gear and the synchro from the main dealer comes to: £273
I agree, I think it would be more advantageous to have another gearbox and grab donor parts. But I'm concerned that I'll end up with not the right ones?
See, even directly for my VIN number, there are FIVE different part numbers for the fifth gear alone!! :o :o :o
Citroen themselves were having a very hard time just trying to find out which part number I needed! :?
What do you think?
It's possible I could change the fifth gears mating cog, but I've not had to remove that as yet and I'd like to just change the worn two parts if possible.
Yamaha R1 1999 26k
romie
ah, this is interesting.
There is a part substitution for 2333 43 (fifth gear)
Any ideas how I can tell for sure that my gearbox is the BE3 and not one of the others?
Is there a number on the gearbox somewhere to fully define it exactly?
Yamaha R1 1999 26k
KennyW
x 165
Unread post by KennyW »
Romie,
In service citroen you print off the profile for your Xantia when it came out of the factory which lists everything including your gearbox type.
I did my daughter's focus gearbox and it was 1 and 2 gear gear shifter which had worn.I'll try and find the company again and see if they do Xantia boxes.
Kenny
C3 1.4 petrol (SWMBO)
romie
uh, there's another one for the synchro part number
no idea what these new RPO numbers mean? uggghhhhhhh. soooo many numbers and references to references depending on references..... ugh :( :( :( :( :(
Yamaha R1 1999 26k
romie
KennyW wrote:Romie,
Kenny
Cheers Kenny
I'll try to figure out where that profile print out link is
Yamaha R1 1999 26k
romie
romie wrote:
KennyW wrote:Romie,
Kenny
Cheers Kenny
aha! Under 'Vehicle characteristics'
So yes, BE3 =D>
Vehicle family XANTIA
AS/RP N° 07105 U7 2 0037
Warranty Start Date 01/01/1990
OPB D00D
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XANTIA
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL LEVEL 1
ENGINE TURBO DIESEL XUD9TE
TRANSMISSION BVM5
INTERIOR TRIM TYPE VOGUE VELVET "BR"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BE3
OTHER BADGE TURBO D
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE XANTIA BADGE
Yamaha R1 1999 26k
KennyW
x 165
Romie,
I got my daughter's bits from autogears. I had quick look but couldn't find Xantia synchros etc but maybe worth phoning them as Peugeots also used the same gearbox. As you have the specifics for your box, they maybe able to help.
Just found this http://www.ebay.co.uk/itm/PEUGEOT-CITRO ... SwymxVMQVa
They may have your gear and synchro
Also have at look at this lot http://www.ebay.co.uk/itm/PEUGEOT-CITRO ... SwymxVMQVa
Kenny
romie
KennyW wrote:Romie,
Kenny
Hi, yes I will. Thanks!
Yes I saw the first ebay item a while ago. Unfortunately it is the wrong part number. it ends 42, mine ends 43. Ratio is different and so is physically different.
And so is the second ebay link you sent.
Oh, they are actually the same part if you look at the ebay numbers in the links you sent.
Thanks tho.
The part numbers I need are:
Citroen Original fifth gear and synchro: 233343 and 238804
Citroen Substitute fifth gear and synchro: 2344E9 and 238832
Fifth gear
DRIVE GEAR
233343
LE-2006
2344E9
Synchro
238804
01 5EME 22X24
LE-2015
238832
Cheers
Yamaha R1 1999 26k
romie
I was looking around on ebay for gearboxes.
I see posts with different 'codes' mentioned.
Like this: "PEUGEOT 406 & CITROEN XANTIA 1.9 TD GEARBOX / TRANSMISSION 5 SPEED CODE 20TA49"
Any idea where do I find that code number?
Is it anything to do with these codes?
GEARBOX (CHARACTERISTICS): BE3
TRANSMISSION : BVM5
Yamaha R1 1999 26k
romie
please no one one say it can only be found under this mess of pipes and wires here? :(
Yamaha R1 1999 26k
