Frustratingly enough Steve, it has been noted on other posts that the pins may not necessarily be exactly as they are on the diagrams! So again, double check the code on the wire. It has also been known that the engine bay fuse box under the BSI can also be problematic, so I would, as a matter of course, disconnect the connectors and ensure they are clean using some electrical contact cleaner (not WD40) and re-connect them. They can sometimes cause problems.bighairybloke wrote:Ok, first I checked the fuse 11 it is fine, there is no corrosion anywhere. Also, the earths all are clean and secure.
I also pulled plug Noir to check there was 12v on pins 1 & 8 and there is none. I suspect there is something amiss here? There should be voltage here to feed the radio and computer etc I believe.
The box with all the fuses and where the black grey and green plugs go in, is there circuitry below that could be faulty? Or a relay?
Cheers
Steve
C5 Mk1 computer powering down
- x 6950
Re: C5 Mk1 computer powering down
KennyW
- x 165
Steve,
I have found in this frustrating type of problem to methodically work back along the wring loom to connector blocks and other such items until 12 V is found and bridge the problem.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
