I seem to remember, but can't find any posts, some members having strong views about the relative merits of various brands of Glow Plugs. Anyone care to remind me please?
The back story is that, for the last few weeks, the 'Green Lady' (our S1 1.9TD Xantia Estate) has fired up first thing on only 3 cylinders, but raising the revs to 2000 has immediately got the 4th to chime in; either another air-leak or a dead/dying glow plug. Yesterday morning was bright and chilly and that 4th cylinder was quite reluctant to light up - my diagnosis: definitely a glow plug!
Last night, I had a bright idea: as my digital meter came with temperature sensor, I could find the duff plug by checking the temperature of their terminals after the light goes out - sadly it doesn't work, even doing it really quickly, they're all around 16-17ºC dropping quickly back to 15º (the engine is 14º), so I guess it's the usual fault of just the plug tip not heating.
I've used someone else's internet connection to get on-line now, and ordered a new router for a start (the dead one is ex-Sky and must be 9+ years old, so I can't complain) before starting to research glow plugs; GSF want £16.21 for NGKs and £17.78 for Beru ones. So the idea of buying 4 and replacing them as a set, has gone out of the window - as has the idea of using my last used-but-good spare.
BTW, I've changed the glow plugs before, so I've got the tools and the technique - I just need is a couple of days when the car won't be needed so I can take out the plugs one-by-one (hopefully not breaking any) until I find the one with the sooty tip; then I can order however many new ones are needed!
Xantia 1.9 glow plugs
Old-Guy
- x 26
superloopy
- x 19
Re: Xantia 1.9 glow plugs
Genuine Citroen plugs ... just sourced for my Xantia TD at a decent price ... £6 per plug. Part number confirmed from service.citroen ... worth swapping the full set.
http://www.ebay.co.uk/itm/191855695595
Sent from my LG-D855 using Tapatalk
Mike
- x 1489
Beru only in a 1.9TD - although the listing above says might be Beru or Bosch - the ones in the pic are Beru.
- x 5673
IIRC Citroen fit Beru as oem.
A mate recently bought a set of four for a 306 1.9 D-Turbo for £34. May have been able to get them for less but had to go to the nearest autoshop before they closed.
elma
- x 284
I always used Bosch then Beru in my latest two diesels. I've had no problems with either.
- x 1746
Beru are OE and top quality. Should be available at any good motor factor.
superloopy
- x 19
I agree but in this instance it's the price point that's important.white exec wrote:Beru are OE and top quality. Should be available at any good motor factor.
£6 a plug should allow OP to change ALL plugs, he had been quoted a lot more from motor factors.
I received BERU plugs.
Mike
spider
- x 77
I'd personally only want to fit Beru or Bosch.
The ones in my last TD were Bosch and were still alive after about 6 years...
They were not cheap though from what I recall but I did go to a Bosch agent for them as I was in a rush.
Andy.
uncle buck
- x 10
I think a couple of the posts you may remember may have been mine...
Cheers.
uncle buck wrote:When fitting the new glow plugs give the threads of them a smear of copper slip grease to aid removal in the future.
Stay well away from NGK glow plugs ....they're not suited to the TD engine...I have this on good authority.
Cheers.
Taken from this thread.... http://www.frenchcarforum.co.uk/forum/v ... hp?t=28111uncle buck wrote:...Was told by an NGK themselves that their glow plugs "Maybe weren't best suited" to the 1.9 TD engine after fitting 2 sets on the trot & suffering very poor cold starting problems. The glow plugs were actually sent back to NGK for tests and the above was their response!
Cheers.
Cheers.
2001 Xsara II 1.4 LX
chinkostu
- x 30
Definately Beru, I got mine from Carparts4less (ECP technically!) when they had a discount on and paid £29 for the 4 of them, and that was a year ago now (just dug the invoice up).
The ebay ones look like they have the same markings as mine did, and the lack of nuts!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 8406
Another vote for Beru here...
I found NGK disappointing...
- x 5673
There have been a number of folks found NGK unsuitable for PSA engines.
chinkostu
- x 30
I can't remember the ones I bought for the 206, definately weren't beru and they didn't do the job.myglaren wrote:There have been a number of folks found NGK unsuitable for PSA engines.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
